UC540 and ISDN BRI (British Telecom)
Netmetix007
Hello
We have installed a UC540-BRI system and it will not make inbound/outbound calls via ISDN 2 BRI.
ISDN status looks fine but it does not work, inbound are generally unobtainable/engaged and outbound display "Unknown Number".
British Telecom confirm that the lines are fine but I am not convinced we are using the right ISDN setting and seems nobody at British Telecom know either!
Below is the current ISDN status along with the configuration of each interface.
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
        dsl 2, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 2 CCBs = 0
    The Free Channel Mask:  0x80000003
ISDN BRI0/1/1 interface
        dsl 3, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 3 CCBs = 0
    Total Allocated ISDN CCBs = 0
interface BRI0/1/0
 no ip address
 isdn switch-type basic-net3
 isdn not-end-to-end 64
 isdn point-to-point-setup
 isdn incoming-voice voice
 isdn send-alerting
 isdn sending-complete
 isdn static-tei 0
end
paolo bevilacqua
These are symptom of misconfiguration, possibly this is first cisco UC you have installed.
You can take "debug isdn q931" with "term mon" to see what happens.
Moved:
Dan Lukes
