UC560 CLI configuration after CCA
srirgopa
Hi all,
If my UC560 is configured using CCA and then I want to make changes using CLI( assuming that CCA is not available on laptop) , is that supported?
Sriram
Mark Malone
Just so your aware if you make changes to a UC500 by cli TAC will not support it anymore if theres an issue
Hi Mark,
Thankyou for the answer. This is exactly what I was looking for as i did not see a recent thread on this support.
To do remote configuration can I enable it through CCA  for the VPN?
Sriram
Hey yes you should be able to
https://supportforums.cisco.com/discussion/11095896/remote-access-cca-30-and-uc500-system
Thankyou for the quick response Mark.
