01-04-2012 02:38 PM - edited 03-21-2019 05:09 AM
Can anyone help me configure Cisco IP Conference Phone 7937G with UC560. Is there any special steps to perform for configuration or just as a normal Cisco IP phone connect directly to the router, assign extension using CCA and it will start working?
Do I need to perform additional steps to configure this conference phone like registering it with TAPS? How can I activate the conference phone and how can I get the TAPS extension to activate it?
Thank you for your time and consideration.
Veeral
01-05-2012 12:09 AM
Should be the same as configuring any other phone. I have seen issues with using non US locale and the phone failing to register so if you are not in the US and you have a non US locale configured switch to US to test.
01-05-2012 07:43 AM
Thank you Craig for helping me out. I appreciate it. I will be using USlocale since this installation is in US.
Again thank you for your help.
Veeral
01-05-2012 06:43 PM
Hi Veeral,
Please ensure the following:
This should cover the setup, the rest can be achieved on the system itself not so much the phone
Cheers,
David.
