09-12-2011 09:22 AM - edited 03-21-2019 04:39 AM
Hi All,
Has anyone gotten FAC to work with the UC560? The box only crashing when the voip is enabled. When i shutdown the voip it makes the calls successfully.
can help is greatly appreciated
here is the configuration
Place the files in flash enter_account.au and enter_pin.au
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authentication login h323 local
aaa authorization exec default local
aaa authorization exec h323 local
aaa authorization network sdm_vpn_group_ml_1 local
aaa authorization network h323 local
application
service clid_authen_collect
param uid-len 3
param pin-len 6
dial-peer voice 50 voip
destination-pattern 9[2-8]......
session target ipv4:192.168.20.1
incoming called-number 9[2-8]......
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 100 pots
preference 1
port 0/1/0
forward-digits 7
09-13-2011 07:03 AM
Hi Andrian;
Please stay tuned for help. I will ask a colleague to give you a hand on this.
Alberto
09-13-2011 12:18 PM
Hello Andrian,
There are a few things I noticed, not sure if they are just left out, or not configured.
Your config does not have any usernames/passwords configured, and the dial-peer is pointing to the CME address. Here is the info I found, with the steps to configure FAC.
https://supportforums.cisco.com/docs/DOC-9795/
application
param uid-len 3
param pin-len 3
aaa new-model
username 201 password 123
username 201 autocommand exit
username 202 password 321
username 202 autocommand exit
dial-peer voice 5500 voip
description International Calls
destination-pattern 9011.T
session target ipv4:10.1.1.1
incoming called-number 9011.T
codec g711ulaw
no vad
Thank you,
Darren
09-13-2011 12:45 PM
I have the username and password in the configuration and also i've configure 192.168.20.1 as the cme ip address.
05-25-2012 03:10 PM
could you solve it? I have the same problem
Best Regards
05-26-2012 04:55 AM
hello Alan,
got the issue fixed . you need to upgrade the uc560 version to 8.6 .
regards
Chris Henderson
05-27-2012 09:31 PM
Well the most recent is the 8.2
Thanks, let me try
best regards
05-31-2012 08:53 AM
hello Alan ,
following up to see if you got the issue resolved ?
Chris Henderson
06-03-2012 05:21 PM
hello Chris,
I could resolve it thanks, in my case it was problem with the configuration.
best regards
12-19-2012 11:02 AM
Excuse me, what was your configuration error?
01-09-2013 10:23 AM
Hello Erick,
I do not remember, but works when apply a Factory Reset and reapply the configuration.
Best Regards
01-09-2013 10:33 AM
hahaha i think the last resource always works (reseting the device). I did that on our 3825 and FACs works well.
01-14-2013 08:28 AM
nice hear that,
Best Regards
