UC560 license using CLI
tknapp
I have a UC560. I want to add 8 more user license.  I want to do this using CLI.
We have issues loading the CCA tool.
How do I go about using CLI to install/Authorize/Activate the license with out using CLI?
Thankws!
Nathan Compton
Level 4
Level 4
First off, you need to register the PAK number to your UC560.  You can do that here:
https://tools.cisco.com/SWIFT/Licensing/RegistrationServlet
Once it is registered, you should be emailed a zip file.  Extract that and you will have a .lic file.
Upload this file to the UC560 with TFTP:
UC560#copy tftp flash
Finally install the license with the following command:
UC560#license install flash:(filename)
There is also a technical enablement lab on installing the license:
https://supportforums.cisco.com/docs/DOC-9761
Adam Compton
Nathan Compton
Level 4
Level 4
Adam Compton
thank you for the answer.  Worked great.
