All,Two questions in a single post.1. We have an issue where the receptionist calls external party #1 (outside UC540) and conferences an inbound caller #2 (outside UC) together. Then, when the receptionist hangs up, only the inbound caller #2 ca...
Hi All,We are a Cisco partner and I am in the process of preparing for Unified Call Manager Express Specialization certification and would like some direction in purchasing a Cisco Router/CUE for testing under the NFR program.I would like to know wha...
Hi,I'm implementing a UC520 system for a customer, they have an existing infrastructure which are two numbers of 3560 switches and 1841 Router.They have about 4 different Vlans configured and the workstation vlan is 30 and the voice vlan is 40.I have...
All,We added a PSTN for voicemail via CCA (configure>voicemail>voicemail pstn #), but the UC does not answer the line. When we called the PSTN number's we discovered that two of the six lines are not answered by the UC's AA. Those two lines are on ...
Hi Guys,Why o why o why... Everytime I perform the upgrade using cca 2.2.4 and the latest software packs I always get and issue when trying to upgrade the CUE:++: DEBUG: : se-10-1-10-1#se-10-1-10-1#++: DEBUG: : WARNING:: This command will install t...
Hi,Please i need help. I bought SPA 900 series for use in an office with a UC520 device, i just found out that the UC520 does not support the SPA 900 series phones, i dont know what to do.Does anyone have any suggestions? Can i use ATA to adapt them ...
Hi,we have some issues with the UC550 connecting itself to an accesspoint via CCA from a router. The connection works fine and calls can be made, it's just the connection for while administering the UC540.Setup (only relevant parts):--- wan --- route...
All,All voice mail rom either internal or external callers are off by 7 hours.We are configured for PST.Please advise.It seems like CUE or CME may by the culprit.
I have an asterisk trixbox ce system and some phone calls are not disconnecting which I beleive are also causing our phone calls to drop.Software Version:6.1.3(a)I have contacted trixbox support and they said the system sends the phone a BYE message,...
Hello again...This is a new deployment of UC540 and a ESW 24 port POE switch.Our new ESW 24 port POE is stating the status of all up ports are HALF duplex. All the ports have been given a smartport role that is appropriate for its current usage.Any ...
Trying to decipher a datahseet and hoped you might have some insight. Call Manager has listed that "Auto attendant-Bundled with Cisco CallManager via the Extended Services CD." but I have not been able to confirm if that CD comes with it or is se...
Hi,The company where I work is going to buy a large number of IP phones SPA525G and I want to know if it is possible to configure massively? If so, the configuration file is XML? My company does not use CCM.Thanks
Hi AllIs extension mobility supported on the UC500 platform? If this is possible can someone please provided out of band configuration guidelines to implement it.Steve
