UC560 number format invalid
mitchamrict
Hello All,
At a customer site we are installing a uc560. Everything works fine except 1 thing.
The ISP who is offering us the phone numbers can only offer us 8 digit's instead of 9 digits.
The number of a single isdn line is working fine as shown in the debug below.
   Bearer Capability i = 0x8090A3
                 Standard = CCITT
                 Transfer Capability = Speech
                 Transfer Mode = Circuit
                 Transfer Rate = 64 kbit/s
         Channel ID i = 0xA9838B
                 Exclusive, Channel 11
         Calling Party Number i = 0x0081, '0208882035'
                 Plan:Unknown, Type:Unknown
         Called Party Number i = 0xA1, '433252121'
                 Plan:ISDN, Type:National
000513: Jul 17 16:41:42.531: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0x8
0E2 callID = 0x000C switch = primary-net5 interface = User
000514: Jul 17 16:41:42.535: ISDN Se0/2/0:15 Q931: TX -> SETUP_ACK pd = 8  callr
ef = 0x80E2
000515: Jul 17 16:41:42.559: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callr
ef = 0x80E2
000516: Jul 17 16:41:42.583: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8  callre
f = 0x80E2
000517: Jul 17 16:41:42.607: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8  callref
  = 0x80E2
000518: Jul 17 16:41:42.667: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8  cal
lref = 0x00E2
000519: Jul 17 16:41:42.667: %ISDN-6-CONNECT: Interface Serial0/2/0:10 is now co
nnected to 0208882035 N/A
000520: Jul 17 16:41:46.899: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8  call
ref = 0x00E2
         Cause i = 0x8190 - Normal call clearing
         Progress Ind i = 0x8288 - In-band info or appropriate now available
000521: Jul 17 16:41:46.899: %ISDN-6-DISCONNECT: Interface Serial0/2/0:10  disco
nnected from 0208882035 , call lasted 4 seconds
000522: Jul 17 16:41:46.899: ISDN Se0/2/0:15 Q931: call_disc: PI received in dis
connect; Postpone sending RELEASE for callid 0xC
000523: Jul 17 16:41:46.935: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref
  = 0x80E2
000524: Jul 17 16:41:46.975: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  ca
llref = 0x00E2
The numbers of numberblocks (a range of numbers) are offered with 8  digit's. The problem is that the last digit in the whole number (the  9th) is not offered. See the example below for the number 433506260
                Standard = CCITT
        Channel ID i = 0xA9838C
                Exclusive, Channel 12
        Called Party Number i = 0xA1, '43350626'
000527: Jul 17 16:42:19.075: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0x8
0E3 callID = 0x000D switch = primary-net5 interface = User
000528: Jul 17 16:42:19.079: ISDN Se0/2/0:15 Q931: TX -> SETUP_ACK pd = 8  callr
ef = 0x80E3
000529: Jul 17 16:42:19.087: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  call
ref = 0x80E3
        Cause i = 0x809C - Invalid number format (incomplete number)
000530: Jul 17 16:42:19.167: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref
= 0x00E3
000531: Jul 17 16:42:19.167: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  ca
llref = 0x80E3
The ISP told us that we have to change something on our site because they cannot provide us 9 digits of the numbers in the numberblock.
Does someone has a solution for this?
Thx in advance.
Best regards,
Mitch Rouwette
12 Replies 12
janickle
Hi Mitch,
For the example that you are showing you would just need to change your incoming dial plan to accommodate the 8 digit number being sent by the provider.  For instance in the dial plan for the example you have posted your incoming DID would be 43350626.  Then simply point this to your internal ext.  You can find the incoming number being sent by the provider in the debug under “Called Party Number”.  I hope this helps.
Thank you,
Jason Nickle
Hello Jason,
Thx for the information. The numberblock has around 30 numbers. The last digit (the one i miss) is the digit i need to send the call to the right phone. The extension of the phones is the last 4 digits in the number. so i have 6260, 6261, 6262 en so on.
So i can sent 43350626 to a phone 6260 for example but then is still have the number 6261 till 6279.
Best regards,
Mitch
Hi Mitch,
If that is the case where you have several numbers in that same range, such as 6260, 6261, 6262…. You may need to run a debug for each incoming call to see what the number is that is being passed by the provider.  I hope that they would not forward the same 8 digits for such a scenario.  If the 8 digits are the same for each ext this would be a problem that the provider would need to resolve.  If you have any questions about this I will be happy to further assist you.
Thank you,
Jason Nickle
Hello Jason,
Thx for the information again .
This is a debug of the number that ends on 6262:
000532: Jul 17 16:42:38.019: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref =
0x00E4
                Standard = CCITT
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
000533: Jul 17 16:42:38.019: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0x8
0E4 callID = 0x000E switch = primary-net5 interface = User
000534: Jul 17 16:42:38.023: ISDN Se0/2/0:15 Q931: TX -> SETUP_ACK pd = 8  callr
ef = 0x80E4
000535: Jul 17 16:42:38.031: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  call
ref = 0x80E4
000536: Jul 17 16:42:38.135: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref
= 0x00E4
000537: Jul 17 16:42:38.135: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  ca
llref = 0x80E4
So they all end with 626 in the range of 6260 - 6269
Best regards,
Mitch
Hello Mitch,
If the provider is only going to send you the first 8 digits of a 9 digit number, we can only route based on what they send us.  There is no way for the UC500 to know what that last digit would be.  So that block of 10 number 6260 - 6269 would all have to be directed to the same extension, since all we get is the 626.
There is nothing else that can be done on your end.  (I have never seen a provider do this, and it does not sound normal at all.)
Thank you,
Darren
Thx for the feedback, we have also no experience with this situation. Normaly we receive the right digits and it's no big deal.
Configure
interface se0/2/0:15
isdn overlap-receiving
The final digit can come later, but unless you do the above, router will disconnect and never give CO a chance.
Hello Paolo,
This is the inface config in the uc560 at the moment:
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn map address . plan unknown type unknown
isdn sending-complete
no isdn outgoing ie progress-indicator
trunk-group ALL_T1E1
no cdp enable
Is this oke?
Thx
It is (mostly), please paste here all the dial-peer, voicen tr5anslations and ephone-dn config.
And which exact IOS are you running.
Hello Paolo,
Below the information
ROM: System Bootstrap, Version 15.0(1r)XA3, RELEASE SOFTWARE (fc1)
System image file is "flash:uc500-advipservicesk9-mz.151-2.T4"
! Last configuration change at 12:38:11 CET Sun Jul 22 2012 by amr-ict
! NVRAM config last updated at 12:38:11 CET Sun Jul 22 2012 by amr-ict
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC560-VVV
boot-start-marker
boot-end-marker
card type e1 0 2
logging buffered 4096
enable secret 5 $1$HWB6$vjpl0NSnZnK6LUbQeEyeh0
aaa new-model
aaa group server radius UccServer
server 192.168.1.10 auth-port 1645 acct-port 1646
aaa authentication login default local
aaa authorization exec default local
aaa accounting update newinfo
aaa accounting connection h323
action-type start-stop
broadcast
group UccServer
aaa session-id common
clock timezone CET 1 0
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
crypto pki trustpoint TP-self-signed-3047153847
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3047153847
revocation-check none
crypto pki certificate chain TP-self-signed-3047153847
certificate self-signed 01
  30820255 308201BE A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33303437 31353338 3437301E 170D3132 30333232 31313237
  34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30343731
  35333834 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009907 886BE89C E6E6B2D4 605935F1 F1C3F1C3 8D2CCAFB ADCE0D52 90C9D063
  A4EDA289 61C27F90 9C8A6C74 C95D8DEA 55E116A8 BA3457B7 65503306 270C7CBC
  B121FB22 69BC65B2 5F889165 8B041409 38251AA6 A95A54D4 FE280B92 52B50C52
  8E4DF423 8BFFD842 3A26721B 90461F5A C7391634 D4D6C0B0 0BDBB428 E360FA98
  801B0203 010001A3 7D307B30 0F060355 1D130101 FF040530 030101FF 30280603
  551D1104 21301F82 1D554335 36302D56 56562E76 76766D61 61737472 69636874
  2E6C6F63 616C301F 0603551D 23041830 16801411 5CC8D09D F761B8BC 4C756E34
  2FA090BD BDE9D430 1D060355 1D0E0416 0414115C C8D09DF7 61B8BC4C 756E342F
  A090BDBD E9D4300D 06092A86 4886F70D 01010405 00038181 001A3B80 5F7D672C
  02CB2D45 B11AE8A6 8FD5033E 4F3A4699 6D99B594 8A049D90 FCAE790A 26B214C0
  285086A5 22B2B43E 5D3662F5 2CB84C10 2C9357CD 5CC3654A F7B83477 3B51AAE6
  09C9E0BC 5BF344BE 2013A09D 61EA4402 558FB3AB 4465ED2A 3000D874 B899C466
  EDF746B3 F8761C97 0EECF0BE D5CA1145 28132849 58E5C462 15
      quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.1.1 192.168.1.19
ip dhcp excluded-address 192.168.1.71 192.168.1.255
ip dhcp excluded-address 10.1.1.16
ip dhcp excluded-address 10.1.1.230 10.1.1.240
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip domain name vvvmaastricht.local
ip name-server 208.67.222.222
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp feature access-code
stcapp supplementary-services
port 0/0/0
  fallback-dn 301
port 0/0/1
  fallback-dn 302
port 0/0/2
  fallback-dn 303
port 0/0/3
  fallback-dn 304
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
h323
sip
  registrar server
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 15
max-pool 15
authenticate register
voice register dn  1
number 6275
no-reg
voice register dn  2
number 6276
no-reg
voice register dn  5
number 826
no-reg
voice register dn  6
number 859
no-reg
voice register dn  7
number 878
no-reg
voice register dn  8
number 880
no-reg
voice register pool  1
id mac 586D.8F5C.C038
number 1 dn 1
number 7 dn 7
number 8 dn 8
dtmf-relay rtp-nte
voice-class codec 1
username 100 password 100
no vad
voice register pool  2
id mac 586D.8F5C.BE68
number 1 dn 1
number 2 dn 2
dtmf-relay rtp-nte
voice-class codec 1
no vad
voice translation-rule 1
rule 1 // /0/ type national national
rule 2 // /00/ type international international
voice translation-rule 2
rule 1 /^437999902/ /757/
voice translation-rule 4
rule 1 /626./ /433506262/
rule 2 /6272/ /433506272/
rule 3 /2121/ /433252121/
rule 4 /83[1,2,4,5]/ /433280865/
rule 5 /86[4,6,7]/ /433280865/
rule 6 /838/ /433280838/
rule 7 /833/ /433280838/
rule 8 /84[1,2]]/ /433280838/
rule 9 /^62../ /4335062\1/
rule 15 /^...$/ /437999902/
voice translation-rule 5
rule 1 /^433280808/ /757/
voice translation-rule 6
rule 1 /^433252121/ /2121/
voice translation-rule 7
rule 1 /^433506262/ /729/
voice translation-rule 8
rule 1 /^43328038/ /838/
voice translation-rule 9
rule 1 /^433506263/ /720/
voice translation-rule 10
rule 1 /^433506272/ /719/
voice translation-rule 11
rule 1 /^433280801/ /801/
voice translation-rule 12
rule 1 /^433280803/ /803/
voice translation-rule 13
rule 1 /^433280878/ /878/
voice translation-rule 14
rule 1 /^433280811/ /811/
voice translation-rule 15
rule 1 /^433280808/ /808/
voice translation-rule 16
rule 1 /^433280822/ /822/
voice translation-rule 17
rule 1 /^433280823/ /823/
voice translation-rule 18
rule 1 /^433280826/ /826/
voice translation-rule 19
rule 1 /^433280810/ /810/
voice translation-rule 20
rule 1 /^433280859/ /859/
voice translation-rule 21
rule 1 /^433280831/ /831/
voice translation-rule 22
rule 1 /^433280832/ /832/
voice translation-rule 23
rule 1 /^433280834/ /834/
voice translation-rule 24
rule 1 /^433280835/ /835/
voice translation-rule 25
rule 1 /^433280836/ /836/
voice translation-rule 26
rule 1 /^433280864/ /864/
voice translation-rule 27
rule 1 /^433280865/ /865/
voice translation-rule 28
rule 1 /^433280866/ /866/
voice translation-rule 29
rule 1 /^433280867/ /867/
voice translation-rule 30
rule 1 /^433280838/ /838/
voice translation-rule 31
rule 1 /^433280841/ /841/
voice translation-rule 32
rule 1 /^433280842/ /842/
voice translation-rule 33
rule 1 /^433280843/ /843/
voice translation-rule 34
rule 1 /^433280844/ /844/
voice translation-rule 35
voice translation-rule 36
voice translation-rule 37
rule 1 /^433256260/ /6260/
voice translation-rule 38
rule 1 /^433256260/ /6261/
voice translation-rule 39
voice translation-rule 40
rule 1 /^433256265/ /6265/
voice translation-rule 41
rule 1 /^433256266/ /6266/
voice translation-rule 42
rule 1 /^433256267/ /6267/
voice translation-rule 43
rule 1 /^433256268/ /6268/
voice translation-rule 44
rule 1 /^433256269/ /6269/
voice translation-rule 45
rule 1 /^433256270/ /6270/
voice translation-rule 46
rule 1 /^433256271/ /6271/
voice translation-rule 47
rule 1 /^433256273/ /6273/
voice translation-rule 48
rule 1 /^433256274/ /6274/
voice translation-rule 49
rule 1 /^433256275/ /6275/
voice translation-rule 50
rule 1 /^433256276/ /6276/
voice translation-rule 51
rule 1 /^433256277/ /6277/
voice translation-rule 52
rule 1 /^433256278/ /6278/
voice translation-rule 53
rule 1 /^433256279/ /6279/
voice translation-rule 54
rule 1 /^433280880/ /880/
voice translation-profile 2121
translate calling 1
translate called 6
voice translation-profile 6260
translate calling 1
translate called 37
voice translation-profile 6261
translate calling 1
translate called 38
voice translation-profile 6262
translate calling 1
translate called 7
voice translation-profile 6263
translate calling 1
translate called 9
voice translation-profile 6264
translate calling 1
translate called 39
voice translation-profile 6265
translate calling 1
translate called 40
voice translation-profile 6266
translate calling 1
translate called 41
voice translation-profile 6267
translate calling 1
translate called 42
voice translation-profile 6268
translate calling 1
translate called 43
voice translation-profile 6269
translate calling 1
translate called 44
voice translation-profile 6270
translate calling 1
translate called 45
voice translation-profile 6271
translate calling 1
translate called 46
voice translation-profile 6272
translate calling 1
translate called 10
voice translation-profile 6273
translate calling 1
translate called 47
voice translation-profile 6274
translate calling 1
translate called 48
voice translation-profile 6275
translate calling 1
translate called 49
voice translation-profile 6276
translate calling 1
translate called 50
voice translation-profile 6277
translate calling 1
translate called 51
voice translation-profile 6278
translate calling 1
translate called 52
voice translation-profile 6279
translate calling 1
translate called 53
voice translation-profile 801
translate calling 1
translate called 11
voice translation-profile 801_Called_5
translate calling 3265
translate called 5
voice translation-profile 803
translate calling 1
translate called 12
voice translation-profile 808
translate calling 1
translate called 15
voice translation-profile 810
translate calling 1
translate called 19
voice translation-profile 811
translate calling 1
translate called 14
voice translation-profile 822
translate calling 1
translate called 16
voice translation-profile 823
translate calling 1
translate called 17
voice translation-profile 826
translate calling 1
translate called 18
voice translation-profile 831
translate calling 1
translate called 21
voice translation-profile 832
translate calling 1
translate called 22
voice translation-profile 834
translate calling 1
translate called 23
voice translation-profile 835
translate calling 1
translate called 24
voice translation-profile 836
translate calling 1
translate called 35
voice translation-profile 838
translate calling 1
translate called 30
voice translation-profile 841
translate calling 1
translate called 31
voice translation-profile 842
translate calling 1
translate called 32
voice translation-profile 843
translate calling 1
translate called 33
voice translation-profile 844
translate calling 1
translate called 34
voice translation-profile 859
translate calling 1
translate called 20
voice translation-profile 864
translate calling 1
translate called 26
voice translation-profile 865
translate calling 1
translate called 27
voice translation-profile 866
translate calling 1
translate called 28
voice translation-profile 867
translate calling 1
translate called 29
voice translation-profile 878
translate calling 1
translate called 36
voice translation-profile 880
translate calling 1
translate called 54
voice translation-profile CallBlocking
translate called 2222
voice-card 0
application
service aaservice0 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param aa-pilot 750
  paramspace english index 0
  param second-greeting-time 45
  paramspace english language en
  param call-retry-timer 15
  param voice-mail 700
  param max-time-call-retry 1200
  param service-name bacd
  paramspace english location flash:/bacdprompts/
  param number-of-hunt-grps 1
  param drop-through-option 1
  param handoff-string aaservice0
  param max-time-vm-retry 3
service aaservice1 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param aa-pilot 751
  param call-retry-timer 30
  param max-time-call-retry 600
  paramspace english location flash:/bacdprompts/gr1/
  param drop-through-option 2
  param handoff-string aaservice1
service aaservice2 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param aa-pilot 752
  param drop-through-option 3
  param handoff-string aaservice2
service aaservice3 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param aa-pilot 753
  paramspace english location flash:/bacdprompts/gr2/
  param drop-through-option 4
  param handoff-string aaservice3
service aaservice4 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param aa-pilot 754
  paramspace english location flash:/bacdprompts/gr3
  param drop-through-option 5
  param handoff-string aaservice4
service aaservice5 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param handoff-string aaservice5
  param aa-pilot 755
  paramspace english location flash:/bacdprompts/gr5/
service aaservice6 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param handoff-string aaservice6
  param aa-pilot 756
  paramspace english location flash:/bacdprompts/gr6/
service aaservice7 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param handoff-string aaservice7
  param aa-pilot 757
  paramspace english location flash:/bacdprompts/gr7/
service bacd flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
  param aa-hunt6 A755
  param aa-hunt2 A751
  param number-of-hunt-grps 10
  param aa-hunt7 A756
  param aa-hunt3 A752
  param queue-len 30
  param aa-hunt8 A757
  param aa-hunt4 A753
  param queue-cme-debugs 1
  param aa-hunt5 A754
  param aa-hunt1 A750
license udi pid UC560-FXO-K9 sn FGL160912HU
archive
log config
  logging enable
  logging size 600
  hidekeys
username amr-ict privilege 15 secret 5 $1$kM9Y$rXu/LUR0lzDeENEKxW/8i.
username Markt28 password 0 12345
username Markt27 password 0 12345
username Markt35 password 0 12345
controller E1 0/2/0
pri-group timeslots 1-31
process-max-time 150
gw-accounting aaa
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/0
ip access-group 101 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport access vlan 100
macro description cisco-switch
interface GigabitEthernet0/1/1
switchport mode trunk
interface GigabitEthernet0/1/2
macro description cisco-desktop
spanning-tree portfast
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
no ip address
encapsulation hdlc
no cdp enable
interface Vlan1
ip address 192.168.1.2 255.255.255.0
ip nat inside
interface Vlan90
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 100 in
ip helper-address 10.1.1.1
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip route 10.1.10.1 255.255.255.255 Vlan90
ip radius source-interface Vlan1
logging esm config
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration##NO_ACES_3##
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 101 remark SDM_ACL Category=1
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 permit udp any eq bootps any eq bootps
access-list 101 permit udp any eq bootps any eq bootpc
access-list 101 permit udp host 10.1.1.1 eq domain any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip any any log
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-2.bin alias spa525g-7-4-2.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.loads
tftp-server flash:/phones/7921/APPS-1.3.3.SBN alias APPS-1.3.3.SBN
tftp-server flash:/phones/7921/CP7921G-1.3.3.LOADS alias CP7921G-1.3.3.LOADS
tftp-server flash:/phones/7921/GUI-1.3.3.SBN alias GUI-1.3.3.SBN
tftp-server flash:/phones/7921/MISC-1.3.3.SBN alias MISC-1.3.3.SBN
tftp-server flash:/phones/7921/SYS-1.3.3.SBN alias SYS-1.3.3.SBN
tftp-server flash:/phones/7921/TNUX-1.3.3.SBN alias TNUX-1.3.3.SBN
tftp-server flash:/phones/7921/WLAN-1.3.3.SBN alias WLAN-1.3.3.SBN
tftp-server flash:/phones/7925/APPSH-1.3.3.SBN alias APPSH-1.3.3.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.3.LOADS alias CP7925G-1.3.3.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.3.SBN alias GUIH-1.3.3.SBN
tftp-server flash:/phones/7925/MISCH-1.3.3.SBN alias MISCH-1.3.3.SBN
tftp-server flash:/phones/7925/SYSH-1.3.3.SBN alias SYSH-1.3.3.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.3.SBN alias TNUXH-1.3.3.SBN
tftp-server flash:/phones/7925/WLANH-1.3.3.SBN alias WLANH-1.3.3.SBN
tftp-server flash:/phones/7931/apps31.8-5-3TH1-6.sbn alias apps31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-3TH1-6.sbn alias cnu31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-3TH1-6.sbn alias cvm31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-3TH1-6.sbn alias dsp31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-3TH1-6.sbn alias jar31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-3S.loads alias SCCP31.8-5-3S.loads
tftp-server flash:/phones/7941_7961/apps41.8-5-3TH1-6.sbn alias apps41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-3TH1-6.sbn alias cnu41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-3TH1-6.sbn alias cvm41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-3TH1-6.sbn alias dsp41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-3TH1-6.sbn alias jar41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-3S.loads alias SCCP41.8-5-3S.loads
tftp-server flash:/phones/7942_7962/apps42.8-5-3TH1-6.sbn alias apps42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-5-3TH1-6.sbn alias cnu42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn alias cvm42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-5-3TH1-6.sbn alias dsp42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn alias jar42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-5-3S.loads alias SCCP42.8-5-3S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.8-5-3TH1-6.sbn alias apps45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-3TH1-6.sbn alias cnu45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn alias cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-3TH1-6.sbn alias dsp45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn alias jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-3S.loads alias SCCP45.8-5-3S.loads
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.loads
tftp-server flash:/phones/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/English_United_States/501-dictionary.xml alias English_United_States/501-dictionary.xml
tftp-server flash:/English_United_States/502-dictionary.xml alias English_United_States/502-dictionary.xml
tftp-server flash:/English_United_States/504-dictionary.xml alias English_United_States/504-dictionary.xml
tftp-server flash:/English_United_States/508-dictionary.xml alias English_United_States/508-dictionary.xml
tftp-server flash:/English_United_States/509-dictionary.xml alias English_United_States/509-dictionary.xml
tftp-server flash:/English_United_States/521-dictionary.xml alias English_United_States/521-dictionary.xml
tftp-server flash:/English_United_States/524-dictionary.xml alias English_United_States/524-dictionary.xml
tftp-server flash:/English_United_States/525G-dictionary.xml alias English_United_States/525G-dictionary.xml
tftp-server flash:/English_United_States/525G-kate.xml alias English_United_States/525G-kate.xml
tftp-server flash:/English_United_States/525G-tones.xml alias English_United_States/525G-tones.xml
tftp-server flash:/English_United_States/525G2-dictionary.xml alias English_United_States/525G2-dictionary.xml
tftp-server flash:/English_United_States/525G2-kate.xml alias English_United_States/525G2-kate.xml
tftp-server flash:/English_United_States/525G2-tones.xml alias English_United_States/525G2-tones.xml
tftp-server flash:/English_United_States/7921-dictionary.xml alias English_United_States/7921-dictionary.xml
tftp-server flash:/English_United_States/7921-font.dat alias English_United_States/7921-font.dat
tftp-server flash:/English_United_States/7921-kate.utf-8.xml alias English_United_States/7921-kate.utf-8.xml
tftp-server flash:/English_United_States/7921-kate.xml alias English_United_States/7921-kate.xml
tftp-server flash:/English_United_States/7960-tones.xml alias English_United_States/7960-tones.xml
tftp-server flash:/English_United_States/be-sccp.jar alias English_United_States/be-sccp.jar
tftp-server flash:/English_United_States/CME-locale-en_US-English-8.1.2.1.tar.cfg alias English_United_States/CME-locale-en_US-English-8.1.2.1.tar.cfg
tftp-server flash:/English_United_States/g3-tones.xml alias English_United_States/g3-tones.xml
tftp-server flash:/English_United_States/gp-sccp.jar alias English_United_States/gp-sccp.jar
tftp-server flash:/English_United_States/ipc-sccp.jar alias English_United_States/ipc-sccp.jar
tftp-server flash:/English_United_States/mk-sccp.jar alias English_United_States/mk-sccp.jar
tftp-server flash:/English_United_States/rp-sccp.jar alias English_United_States/rp-sccp.jar
tftp-server flash:/English_United_States/tags_file alias English_United_States/tags_file
tftp-server flash:/English_United_States/tc-sccp.jar alias English_United_States/tc-sccp.jar
tftp-server flash:/English_United_States/td-sccp.jar alias English_United_States/td-sccp.jar
tftp-server flash:/English_United_States/utf8_tags_file alias English_United_States/utf8_tags_file
tftp-server flash:/nl-be-sccp.jar alias Dutch_Netherlands/be-sccp.jar
tftp-server flash:/nl-gp-sccp.jar alias Dutch_Netherlands/gp-sccp.jar
tftp-server flash:/nl-ipc-sccp.jar alias Dutch_Netherlands/ipc-sccp.jar
tftp-server flash:/7921-dictionary.xml alias Dutch_Netherlands/7921-dictionary.xml
tftp-server flash:/7921-font.dat alias Dutch_Netherlands/7921-font.dat
tftp-server flash:/7921-kate.utf-8.xml alias Dutch_Netherlands/7921-kate.utf-8.xml
tftp-server flash:/7921-kate.xml alias Dutch_Netherlands/7921-kate.xml
tftp-server flash:nl-mk-sccp.jar alias Dutch_Netherlands/tc-sccp.jar
tftp-server flash:nl-td-sccp.jar alias Dutch_Netherlands/td-sccp.jar
tftp-server flash:/phones/7906_7911/apps11.8-5-4RH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-4RH1-6.sbn alias cnu11.8-5-4RH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-4RH1-6.sbn alias cvm11sccp.8-5-4RH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-4RH1-6.sbn alias dsp11.8-5-4RH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-4RH1-6.sbn alias jar11sccp.8-5-4RH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-TRH1-6.sbn alias dsp11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/apps11.8-5-4TH1-6.sbn alias apps11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-4TH1-6.sbn alias cnu11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-4TH1-6.sbn alias cvm11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-4TH1-6.sbn alias jar11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-4S.loads alias SCCP11.8-5-4S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7914/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:/phones/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:/phones/7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:/phones/7921/APPS-1.3.4SR1.SBN alias APPS-1.3.4SR1.SBN
tftp-server flash:/phones/7921/CP7921G-1.3.4SR1.LOADS alias CP7921G-1.3.4SR1.LOADS
tftp-server flash:/phones/7921/GUI-1.3.4SR1.SBN alias GUI-1.3.4SR1.SBN
tftp-server flash:/phones/7921/MISC-1.3.4SR1.SBN alias MISC-1.3.4SR1.SBN
tftp-server flash:/phones/7921/SYS-1.3.4SR1.SBN alias SYS-1.3.4SR1.SBN
tftp-server flash:/phones/7921/TNUX-1.3.4SR1.SBN alias TNUX-1.3.4SR1.SBN
tftp-server flash:/phones/7921/WLAN-1.3.4SR1.SBN alias WLAN-1.3.4SR1.SBN
tftp-server flash:/phones/7925/APPSH-1.3.4SR1.SBN alias APPSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.4SR1.LOADS alias CP7925G-1.3.4SR1.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.4SR1.SBN alias GUIH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/MISCH-1.3.4SR1.SBN alias MISCH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.4SR1.SBN alias SYSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.4SR1.SBN alias TNUXH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.4SR1.SBN alias WLANH-1.3.4SR1.SBN
tftp-server flash:/phones/7931/apps31.8-5-4TH1-6.sbn alias apps31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-4TH1-6.sbn alias cnu31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-4TH1-6.sbn alias cvm31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-4TH1-6.sbn alias dsp31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-4TH1-6.sbn alias jar31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-4S.loads alias SCCP31.8-5-4S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-20-0.bin alias cmterm_7936.3-3-20-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.bin
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.8-5-4TH1-6.sbn alias apps41.8-5-4TH1-6.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-4TH1-6.sbn alias cnu41.8-5-4TH1-6.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-4TH1-6.sbn alias cvm41sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-4TH1-6.sbn alias dsp41.8-5-4TH1-6.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-4TH1-6.sbn alias jar41sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-4S.loads alias SCCP41.8-5-4S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7945_7965/apps45.8-5-4TH1-6.sbn alias apps45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-4TH1-6.sbn alias cnu45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-4TH1-6.sbn alias cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-4TH1-6.sbn alias dsp45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-4TH1-6.sbn alias jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-4S.loads alias SCCP45.8-5-4S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.8-5-4TH1-6.sbn alias apps70.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-4TH1-6.sbn alias cnu70.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-4TH1-6.sbn alias cvm70sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-4TH1-6.sbn alias dsp70.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-4TH1-6.sbn alias jar70sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-4S.loads alias SCCP70.8-5-4S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/apps75.8-5-4TH1-6.sbn alias apps75.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-4TH1-6.sbn alias cnu75.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-4TH1-6.sbn alias cvm75sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-4TH1-6.sbn alias dsp75.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-4TH1-6.sbn alias jar75sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-4S.loads alias SCCP75.8-5-4S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:speeddialkura.txt alias Speeddiavvvl1.txt
tftp-server flash:speeddialkura.csv alias Speeddiavvvl1.csv
tftp-server flash:Speeddialvvvl1.txt alias Speeddialvvvl1.txt
tftp-server flash:Speeddialvvv1.txt alias Speeddialvvv1.txt
radius-server host 192.168.1.10 auth-port 1645 acct-port 1646
radius-server key radius@vvv
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
voice-port 0/0/0
compand-type a-law
cptone NL
timeouts ringing infinity
station-id number 401
caller-id enable
voice-port 0/0/1
compand-type a-law
cptone NL
station-id number 402
caller-id enable
voice-port 0/0/2
compand-type a-law
cptone NL
station-id number 403
caller-id enable
voice-port 0/0/3
compand-type a-law
cptone NL
station-id number 404
caller-id enable
voice-port 0/2/0:15
local-alerting
bearer-cap Speech
voice-port 0/1/0
trunk-group ALL_FXO 64
compand-type a-law
cptone NL
connection plar opx 700
impedance complex2
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
voice-port 0/1/1
compand-type a-law
cptone NL
impedance complex2
description Configured by CCA 4 FXO-0/1/1-OP
caller-id enable
voice-port 0/1/2
compand-type a-law
cptone NL
impedance complex2
description Configured by CCA 4 FXO-0/1/2-OP
caller-id enable
voice-port 0/1/3
compand-type a-law
cptone NL
impedance complex2
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
service stcapp
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 700
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 pots
direct-inward-dial
port 0/2/0:15
dial-peer voice 58 pots
trunkgroup ALL_T1E1
corlist outgoing call-emergency
description **CCA*Netherlands-6-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 0112
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 112
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_T1E1
corlist outgoing call-local
description **CCA*Netherlands-6-Digit*Lokaal 6 cijfers subscriber**
preference 3
destination-pattern 0[2-8].....
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_T1E1
corlist outgoing call-national
description **CCA*Netherlands-6-Digit*Nationaal (geografisch)**
preference 3
destination-pattern 00[1-57]........
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*Mobiele telefonie**
preference 3
destination-pattern 006........
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*Videotex / datadiensten**
preference 3
destination-pattern 0067[0-57-9]..
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 006728[14]....
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0067364....
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_T1E1
corlist outgoing call-international
description **CCA*Netherlands-6-Digit*Internationaal**
preference 3
destination-pattern 000[1-9]T
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_T1E1
corlist outgoing call-toll-free
description **CCA*Netherlands-6-Digit*0800 nummer**
preference 3
destination-pattern 008000[013-8]..
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 008000[29].....
forward-digits all
no sip-register
dial-peer voice 79 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 80 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 008001...
forward-digits all
no sip-register
dial-peer voice 81 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 82 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 008003......
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 84 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 00800[25-9][01]..
forward-digits all
no sip-register
dial-peer voice 85 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 86 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 00800[25-9][2-9].....
forward-digits all
no sip-register
dial-peer voice 87 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 88 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 008004[024578].....
forward-digits all
no sip-register
dial-peer voice 89 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 90 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 008004[1369]..
forward-digits all
no sip-register
dial-peer voice 91 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 92 pots
trunkgroup ALL_T1E1
corlist outgoing call-local-plus
description **CCA*Netherlands-6-Digit*VPN**
preference 3
destination-pattern 0082T
forward-digits all
no sip-register
dial-peer voice 93 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 94 pots
trunkgroup ALL_T1E1
corlist outgoing call-national-plus
description **CCA*Netherlands-6-Digit*Persoonlijke assistentdiensten**
preference 3
destination-pattern 008[47].......
forward-digits all
no sip-register
dial-peer voice 95 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 96 pots
description **CCA*Netherlands-6-Digit*Openbare elektronische
no sip-register
dial-peer voice 98 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*ondernemingen en instellingen**
preference 3
destination-pattern 0088.......
forward-digits all
no sip-register
dial-peer voice 99 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 101 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*0900 nummer**
preference 3
destination-pattern 0090[069]9[235-8]..
forward-digits all
no sip-register
dial-peer voice 102 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 103 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0090[069]0[0-35-9]..
forward-digits all
no sip-register
dial-peer voice 104 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 105 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0090[069]1[345789]..
forward-digits all
no sip-register
dial-peer voice 106 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 107 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0090[069]04.....
forward-digits all
no sip-register
dial-peer voice 108 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 109 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0090[069]1[0126].....
forward-digits all
no sip-register
dial-peer voice 110 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 111 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0090[069]8[2579].....
forward-digits all
no sip-register
dial-peer voice 112 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 113 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0090[069]9[0149].....
forward-digits all
no sip-register
dial-peer voice 114 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 115 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0090[069][2-7]......
forward-digits all
no sip-register
dial-peer voice 116 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 117 pots
no sip-register
dial-peer voice 119 pots
description **CCA*Netherlands-6-Digit*Europees diensten met een
no sip-register
dial-peer voice 121 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*Informatienummers- 1e deel**
preference 3
destination-pattern 018[02-9].
forward-digits all
no sip-register
dial-peer voice 122 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 123 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*Informatienummers- 2e deel**
preference 3
destination-pattern 0181[0-79]
forward-digits all
no sip-register
dial-peer voice 124 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 125 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 12XX/18XX**
preference 3
destination-pattern 01[28]..
forward-digits all
no sip-register
dial-peer voice 126 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 127 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 13XX**
preference 3
destination-pattern 013[03-9].
forward-digits all
no sip-register
dial-peer voice 128 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 129 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 13X**
preference 3
destination-pattern 013[12]
forward-digits all
no sip-register
dial-peer voice 130 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 131 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 1400**
preference 3
destination-pattern 01400
forward-digits all
no sip-register
dial-peer voice 132 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 133 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 140XXX**
preference 3
destination-pattern 01401[035]
forward-digits all
no sip-register
dial-peer voice 134 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 135 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 14XXXXX**
preference 3
destination-pattern 01401[1678].
forward-digits all
no sip-register
dial-peer voice 136 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 137 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 14XXX**
preference 3
destination-pattern 01402[0346]
forward-digits all
no sip-register
dial-peer voice 138 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 139 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 14XXXX**
preference 3
destination-pattern 01402[259].
forward-digits all
no sip-register
dial-peer voice 140 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 141 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 01403[03568]
forward-digits all
no sip-register
dial-peer voice 142 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 143 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 01403[124].
forward-digits all
no sip-register
dial-peer voice 144 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 145 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 01404[0356]
forward-digits all
no sip-register
dial-peer voice 146 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 147 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 01404[1789].
forward-digits all
no sip-register
dial-peer voice 148 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 149 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 01405[0358]
forward-digits all
no sip-register
dial-peer voice 150 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 151 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 01405[124679].
forward-digits all
no sip-register
dial-peer voice 152 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 153 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 01407.
forward-digits all
no sip-register
dial-peer voice 154 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 155 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 0141.
forward-digits all
no sip-register
dial-peer voice 156 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 157 pots
trunkgroup ALL_T1E1
description **CCA*Netherlands-6-Digit*service nr 1451**
preference 3
destination-pattern 01451
forward-digits all
no sip-register
dial-peer voice 158 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 3000 pots
description 801
translation-profile incoming 801_Called_5
incoming called-number 80[1-3]
direct-inward-dial
port 0/2/0:15
dial-peer voice 5000 voip
description *** CCA BACD ***
service aaservice0
destination-pattern 750
session target ipv4:192.168.1.2
incoming called-number 750
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2010 voip
description ** cue prompt number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 720
b2bua
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 740
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 11 pots
description Inkomend 808
translation-profile incoming 808
incoming called-number 433280808
direct-inward-dial
dial-peer voice 12 pots
description Inkomend 2121
translation-profile incoming 2121
incoming called-number 433252121
direct-inward-dial
dial-peer voice 13 pots
description Inkomend 6262
translation-profile incoming 6262
incoming called-number 433506262
direct-inward-dial
dial-peer voice 14 pots
description Inkomend 838
translation-profile incoming 838
incoming called-number 433280838
direct-inward-dial
dial-peer voice 10 pots
description Inkomend 867
translation-profile incoming 867
incoming called-number 437999902
direct-inward-dial
dial-peer voice 2013 voip
description ** cue auto attendant5 number **
destination-pattern 719
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2006 voip
description ** cue auto attendant2 number **
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2007 voip
description ** cue auto attendant3 number **
destination-pattern 715
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 5001 voip
service aaservice1
destination-pattern 751
incoming called-number 751
codec g711ulaw
no vad
dial-peer voice 5002 voip
service aaservice2
destination-pattern 752
incoming called-number 752
codec g711ulaw
no vad
dial-peer voice 2008 voip
description ** cue auto attendant4 number **
destination-pattern 716
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 5003 voip
service aaservice3
destination-pattern 753
incoming called-number 753
codec g711ulaw
no vad
dial-peer voice 15 pots
description Inkomend 6263
translation-profile incoming 6263
incoming called-number 433506263
direct-inward-dial
dial-peer voice 2020 voip
description ** cue auto attendant6 number **
destination-pattern 718
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 16 pots
description Inkomend 6272
translation-profile incoming 6272
incoming called-number 433506272
direct-inward-dial
dial-peer voice 5004 voip
service aaservice4
destination-pattern 754
incoming called-number 754
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
destination-pattern 710
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 21 pots
description Inkomend 801
incoming called-number 433280801
direct-inward-dial
dial-peer voice 22 pots
description Inkomend 803
translation-profile incoming 803
incoming called-number 433280803
direct-inward-dial
dial-peer voice 23 pots
description Inkomend 878
translation-profile incoming 878
incoming called-number 433280878
direct-inward-dial
dial-peer voice 24 pots
description Inkomend 811
translation-profile incoming 811
incoming called-number 433280811
direct-inward-dial
dial-peer voice 25 pots
direct-inward-dial
dial-peer voice 26 pots
description Inkomend 822
translation-profile incoming 822
incoming called-number 433280822
direct-inward-dial
dial-peer voice 27 pots
description Inkomend 823
translation-profile incoming 823
incoming called-number 433280823
direct-inward-dial
dial-peer voice 28 pots
description Inkomend 826
translation-profile incoming 826
incoming called-number 433280826
direct-inward-dial
dial-peer voice 29 pots
description Inkomend 810
translation-profile incoming 810
incoming called-number 433280810
direct-inward-dial
dial-peer voice 30 pots
description Inkomend 859
translation-profile incoming 859
incoming called-number 433280859
direct-inward-dial
dial-peer voice 31 pots
description Inkomend 831
translation-profile incoming 831
incoming called-number 433280831
direct-inward-dial
dial-peer voice 32 pots
description Inkomend 832
translation-profile incoming 832
incoming called-number 433280832
direct-inward-dial
dial-peer voice 33 pots
description Inkomend 834
translation-profile incoming 834
incoming called-number 433280834
direct-inward-dial
dial-peer voice 34 pots
description Inkomend 835
translation-profile incoming 835
incoming called-number 433280835
direct-inward-dial
dial-peer voice 35 pots
description Inkomend 8836
translation-profile incoming 836
incoming called-number 433280836
direct-inward-dial
dial-peer voice 36 pots
description Inkomend 864
translation-profile incoming 864
incoming called-number 433280864
direct-inward-dial
dial-peer voice 37 pots
description Inkomend 865
translation-profile incoming 865
incoming called-number 433280865
direct-inward-dial
dial-peer voice 38 pots
description Inkomend 866
translation-profile incoming 866
incoming called-number 433280866
direct-inward-dial
dial-peer voice 39 pots
incoming called-number 433280867
direct-inward-dial
dial-peer voice 40 pots
direct-inward-dial
dial-peer voice 41 pots
description Inkomend 841
translation-profile incoming 841
incoming called-number 433280841
direct-inward-dial
dial-peer voice 42 pots
description Inkomend 842
translation-profile incoming 842
incoming called-number 433280842
direct-inward-dial
dial-peer voice 43 pots
description Inkomend 843
translation-profile incoming 843
incoming called-number 433280843
direct-inward-dial
dial-peer voice 44 pots
description Inkomend 844
translation-profile incoming 844
incoming called-number 433280844
direct-inward-dial
dial-peer voice 45 pots
description Inkomend 836
direct-inward-dial
dial-peer voice 46 pots
direct-inward-dial
dial-peer voice 47 pots
description Inkomend 6260
translation-profile incoming 6260
incoming called-number 433256260
direct-inward-dial
dial-peer voice 48 pots
description Inkomend 6261
translation-profile incoming 6261
incoming called-number 433256261
direct-inward-dial
dial-peer voice 49 pots
description Inkomend 6264
translation-profile incoming 6264
incoming called-number 433256264
direct-inward-dial
dial-peer voice 160 pots
description Inkomend 6265
translation-profile incoming 6265
incoming called-number 433256265
direct-inward-dial
dial-peer voice 161 pots
description Inkomend 6266
translation-profile incoming 6266
incoming called-number 433256266
direct-inward-dial
dial-peer voice 162 pots
description Inkomend 6267
translation-profile incoming 62667
incoming called-number 433256267
direct-inward-dial
dial-peer voice 163 pots
description Inkomend 6268
translation-profile incoming 6268
incoming called-number 433256268
direct-inward-dial
dial-peer voice 164 pots
description Inkomend 6269
translation-profile incoming 6269
incoming called-number 433256269
direct-inward-dial
dial-peer voice 165 pots
description Inkomend 6270
translation-profile incoming 70
incoming called-number 433256270
direct-inward-dial
dial-peer voice 166 pots
description Inkomend 6271
translation-profile incoming 6271
incoming called-number 433256271
direct-inward-dial
dial-peer voice 167 pots
description Inkomend 6273
translation-profile incoming 6273
incoming called-number 433256273
direct-inward-dial
dial-peer voice 168 pots
description Inkomend 6274
translation-profile incoming 6274
incoming called-number 433256274
direct-inward-dial
dial-peer voice 169 pots
description Inkomend 6275
translation-profile incoming 6275
incoming called-number 433256275
direct-inward-dial
dial-peer voice 170 pots
description Inkomend 6276
translation-profile incoming 6276
incoming called-number 433256276
direct-inward-dial
dial-peer voice 171 pots
description Inkomend 6277
translation-profile incoming 6277
incoming called-number 433256277
direct-inward-dial
dial-peer voice 172 pots
description Inkomend 6278
translation-profile incoming 6278
incoming called-number 433256278
direct-inward-dial
dial-peer voice 173 pots
description Inkomend 6279
translation-profile incoming 6279
incoming called-number 433256279
direct-inward-dial
dial-peer voice 174 pots
description Inkomend 880
translation-profile incoming 880
incoming called-number 433280880
direct-inward-dial
dial-peer voice 5008 voip
service aaservice5
destination-pattern 755
incoming called-number 755
codec g711ulaw
no vad
dial-peer voice 5009 voip
service aaservice6
destination-pattern 756
incoming called-number 756
codec g711ulaw
no vad
dial-peer voice 5010 voip
service aaservice7
destination-pattern 757
incoming called-number 757
codec g711ulaw
no vad
dial-peer voice 159 pots
trunkgroup ALL_T1E1
description lokaal
destination-pattern [23456789]......
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 192.168.1.2 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone ehookEnable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message VVV Maastricht
url directories http://10.1.1.20/localdirectory
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale U4 load CME-locale-nl_NL-Dutch-8.1.2.1.tar
user-locale 1 NL
network-locale U4
network-locale 1 NL
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.8-5-4S
load 7911 SCCP11.8-5-4S
load 7921 CP7921G-1.3.4SR1
load 7925 CP7925G-1.3.4SR1
load 7931 SCCP31.8-5-4S
load 7936 cmterm_7936.3-3-20-0
load 7937 apps37sccp.1-3-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-4S
load 7941GE SCCP41.8-5-4S
load 7942 SCCP42.8-5-3S
load 7945 SCCP45.8-5-4S
load 7961 SCCP41.8-5-4S
load 7961GE SCCP41.8-5-4S
load 7962 SCCP42.8-5-3S
load 7965 SCCP45.8-5-4S
load 7970 SCCP70.8-5-4S
load 7971 SCCP70.8-5-4S
load 7975 SCCP75.8-5-4S
load 521G-524G cp524g-8-1-17
time-zone 23
time-format 24
date-format dd-mm-yy
bulk-speed-dial list 0 Speeddial1vvv.txt
bulk-speed-dial list 6 Speeddial6gidsenvast.txt
bulk-speed-dial list 7 Speeddial7gidsenmobiel.txt
voicemail 700
max-conferences 8 gain -6
call-forward pattern .T
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$YXxI$NwXIy1vvoVJRoHoS4SR5j.
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 0.T
transfer-pattern 6... blind
transfer-pattern 0T
transfer-pattern 5T
transfer-pattern 2T
transfer-pattern 3T
transfer-pattern 4T
transfer-pattern 6T
transfer-pattern 7T
transfer-pattern 8T
transfer-pattern 9T
transfer-pattern 880
transfer-pattern 878
transfer-pattern 6275
transfer-pattern 6276
transfer-pattern 826
transfer-pattern 859
secondary-dialtone 0
night-service day Sat 09:00 17:00
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-template  20
ephone-dn  1  dual-line
number 801
label Winkel2
description Winkel2
name Winkel twee
call-forward busy 803
call-forward noan 803 timeout 20
ephone-dn  2  dual-line
number 803
label Winkel
description Winkel
name Winkel
ephone-dn  3  dual-line
number 810
label Bel-etage
description Bel-etage
name Bel-etage
ephone-dn  4  dual-line
number 811
label Vergaderruimte
description Vergaderruimte
name Vergaderruimte
call-forward noan 803 timeout 25
ephone-dn  5  dual-line
number 813
ephone-dn  6  dual-line
number 822
call-forward busy 823
call-forward noan 823 timeout 15
ephone-dn  7  dual-line
number 823
call-forward busy 822
call-forward noan 822 timeout 15
ephone-dn  8  dual-line
number 826
label Post-Balie
description Post-Balie
name Post-Balie
ephone-dn  9
number 831
call-forward busy 808
call-forward noan 808 timeout 20
ephone-dn  10  dual-line
number 8
ephone-dn  11  dual-line
number 833
label Stagiaire1
description Stagiaire1
name Stagiaire1
ephone-dn  12  dual-line
number 834
l
ephone-dn  13  dual-line
number 835
ephone-dn  14  dual-line
number 836
label Reprografie
description Reprografie
name Reprografie
ephone-dn  15  dual-line
number 838
call-forward busy 833
call-forward noan 833 timeout 15
ephone-dn  16  dual-line
number 841
call-forward busy 842
call-forward noan 842 timeout 15
ephone-dn  17  dual-line
number 842
call-forward busy 844
call-forward noan 844 timeout 15
ephone-dn  18  dual-line
number 843
label Stagiaire 2
description Stagiaire 2
name Stagiaire 2
call-forward noan 808 timeout 15
ephone-dn  19  dual-line
number 844
label [844]
description 844
name 844
call-forward busy 843
call-forward noan 843 timeout 15
ephone-dn  20  dual-line
number 859
label Flexruimte
description Flexruimte
name Flexruimte
ephone-dn  21  dual-line
number 864
ephone-dn  22  dual-line
number 865
ephone-dn  23  dual-line
number 866
label [866]
description 866
name 866
ephone-dn  24  dual-line
number 867
label 867
description Dinghuis
name Ding Huis
ephone-dn  26
number 711
name Auto Attendant
hold-alert 30 originator
ephone-dn  27  dual-line
number 6260
ephone-dn  28  dual-line
number 6261
ephone-dn  29  dual-line
number 6264
ephone-dn  30  dual-line
number 6265
ephone-dn  31  dual-line
number 6266
label Stagiaire
name Stagiaire
ephone-dn  32  dual-line
number 6267
ephone-dn  33  dual-line
number 6268
label Planning
description Planning
name Planning
ephone-dn  34  dual-line
number 6269
ephone-dn  36  dual-line
number 6273
ephone-dn  37  dual-line
number 6274
label [6274]
description 6274
name 6274
ephone-dn  38
number 6271
ephone-dn  39
number 6277
ephone-dn  40
number 721 no-reg primary
description *** CCA Floating Extension ***
call-forward all 710
call-forward night-service 720
night-service bell
ephone-dn  41  dual-line
number 722
label VM[722]
description VM722
name VM722
call-forward all 700
ephone-dn  42  dual-line
number 723
label VM[723]
description VM723
name VM723
ephone-dn  43  dual-line
number 724
label VM[724]
description VM724
name VM724
ephone-dn  44  dual-line
number 725
label VM[725]
description VM725
name VM725
ephone-dn  45  dual-line
number 726
label VM[726]
description VM726
name VM726
call-forward busy 700
call-forward noan 700 timeout 10
ephone-dn  46  dual-line
number 6263
ephone-dn  47
number 2121
label Informatie
description Informatie
name Informatie
call-forward all 00433506262
ephone-dn  48
number 729
call-forward all 715
ephone-dn  49  dual-line
number 846
label Medewerkers Online
description Medewerkers Online
name Medewerkers Online
ephone-dn  50  dual-line
number 6299
label [6299]
description 6299
name 6299
ephone-dn  51  dual-line
number 727
label VM[727]
description VM727
name VM727
ephone-dn  55
number 6480
ephone-dn  56
number 6481
ephone-dn  57
number 6482
ephone-dn  58
number 6483
ephone-dn  59
number 270
call-forward all 0433233426
ephone-dn  60
number 272
ephone-dn  596  dual-line
number 6272
The configuratio, being CCA generated, is not clean or optimized, but it appears to be technically correct.
Can you update to IOS in latest SW 8.6? and/or take "debug voip dialpeer" when receiving call.
David Trad
Hi Mitch,
I would like to understand this further if you wouldn't mind?
So your carrier has given you a 30 block in-dial right?
You have a primary number which is: 433252121
And then a subsequent 30 block range that is: 43350626(0-29) right?
If this is the case and they are dropping the last digit, then there is nothing you can do on the Cisco UC-500 to overcome this stupid insane setup they have given you, there is also no reason what so ever for them to drop the last digit unless they are using some crappy dodgy equipment that cannot do proper routing (Which is very possible), and not to mention that this is almost unseen and unheard of, there is no benefit to them to drop the last digit other than a system limitation, and if that was they case who ever supplied that nonsense to them should return the money because it isn't worth $1.
My suggestion to you is either force them to fix up the issue and parse the entire number block to you, or ask for your money back and release from any contract and move to a proper provider who can behave like a real-proper-telco and actually parse through the full national number.
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
