urgent-UC560 cannot ping inernal service modue-CUE
Dear all,
I did all the configuration via vlan90 and loopback interface to reach the service module, but no way.
I also enter to the CUE-offline-restore factory default then configure the ip address and the GW,, is this step nesscarry or it is enough to confiure the Integrated-Service-Engine0/0 from the UC it self????
i did this route (ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0) and (ip route 10.1.10.1 255.255.255.255 vlan 90), but  same issue, no ping.
Below is the show run to access the service module 0/0: Please help to access the CUE with refer to attached.
interface Integrated-Service-Engine0/0
 description Interface used to manage integrated application modulecue is initialized with default IMAP group
 ip unnumbered Vlan90
 no ip route-cache
 service-module ip address 10.1.10.1 255.255.255.252
 service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/3
 description Interface used to communicate with integrated service module
 switchport access vlan 90
 no ip address
interface Vlan90
 ip address 10.1.10.2 255.255.255.252
 ip access-group 103 in
 ip nat inside
 ip virtual-reassembly in
ip route 10.1.10.1 255.255.255.255 Vlan90
regards,
0 Replies 0
