04-12-2011 07:09 AM - edited 03-21-2019 03:56 AM
Hello, Does anyone have an idea why a remote SPA525G2 would sporadically reconnect to the VPN?
There does not seem to be a specific event that causes this. Otherwise the calls are fine.
I can provide more details if needed.
Thank you, Paul
Solved! Go to Solution.
04-13-2011 05:53 AM
7-4-6 comes with the SWP. 7.4.7 is the recommended phone load for UC 500 and SPA50x phones.
For SPA525G or G2, you can go with 7-4-8.
Basically, 7.4.8a is for the SPA50x/30x to resolve a crash or stability issue when the phone is operating in SPCP mode.
Sorry for the confusion
04-12-2011 12:27 PM
What firmware are you using? I had this problem and fixed with a firmware change. I will have to check which one finally worked.
04-12-2011 12:51 PM
Jason, the firmware is whatever is standard in the "8.1" zip load. 7.4.4, I believe.
Let me know what you changed to or from and I will check.
Thank you.
04-12-2011 07:22 PM
Hi Paul,
Is this the same system/phone that you are having the same voice issues with?
Cheers,
David.
04-13-2011 05:47 AM
I changed it to 7.4.7. That seemed to fix the reconnecting issue. Initially I used 7.4.8 but that did not work so well. There are some different threads recommending against 7.4.8.
04-13-2011 05:53 AM
04-13-2011 05:54 AM
David, yes the phone reconnecting is one SPA525G2 used as a remote teleworker. The other SPA525G2 that is having the voice dropping issue is another remote teleworker off the same system.
The system is a UC540, connected to a Windstream T1 via a Cisco 2431 router.
At the office there are just two local phones, a SPA504G and a 7960.
Question. Can the 7.4.7 firmware be "dropped" into the UC540 and automatically update the remote phones?
Please advise. Thank you, Paul
04-13-2011 05:57 AM
Steven, thank you for your continued support, and Congrats on your post milestone!
04-13-2011 07:05 AM
Thanks Paul for the recognition (I joined my first Netpro in 2005, and didn't use it much till 2009 just after we launched the small business portal. And 2400 is nothing. There are folks in Cisco Partner Advisors, TAC guys, etc who spend their day in the communities and exceed this easily :-) Partners exceed my number as well :-) I am happy about that actually so thank you!
And in fact the Small Business community is one where we (Cisco folk) don't earn points because partners don't really mark questions answered, so the larger Cisco doesn't rank it, so there is the proof that I am not here for that.
I use it as a Sales enablement tool and I find it keeps me focused on priorities, guides collateral generation, helps w/ feature roadmap, and keeps partner satisfaction up. What started as a new model of "massively scaling" to the many partners turned into an invaluable tool for Cisco to enjoy IMHO.
I can tell you that the main difference between our community and Partner Central (which by the way has become VERY respectable again) is YOU ALL. The interaction among partners is really what we are after here as well. So thank you too.
04-13-2011 05:58 AM
The firmware can be dropped on the picture of the uc500 on the topology and the phones will update when rebooted. A cool feature that works.
04-13-2011 06:10 AM
Jason, David, Steven, thank you.
I just uploaded the 7.4.7 firmware to the UC540.
I will update this post when we see if this indeed helps correct the issues.
Paul
