10-28-2012 07:29 PM - edited 03-21-2019 06:30 AM
Hi Everybody,
This is my first time to use UC560, with following configuration tool and version
- Cisco Configuration Assistant 3.2(1)
- IOS UC500-ADVIPSRVICESK9-M, version 15.1(4)M4b
but it seems some function working strange
- When open the "Telephony Setup Wizard", the screen stucks at Current progress 99% in Welcome section.
- When open the "Users/Extensions" > "Users and Phones",
it popup a status message box, and "Loadind Voice Related Data..." the status bar stucks at progress 99%
what I did for UC560
- erase startup-config, reload
- username admin privilege 15 password cisco
- vtp mode transparent
- interface vlan2, and ip address 10.0.0.1 255.255.255.0
- line vty 0 4, and login local
- ip http server, and ip http authentication local
Anybody knows what is happening here?
Thanks in advance
Sam
Solved! Go to Solution.
10-29-2012 02:34 PM
Hello Sam,
The easiest way to start is to copy the default config file to startup. The default config file is located in the main flash directory - e.g. UC560-FXO-K9-factory-8.6.0.cfg (this is dependant on your system but it is cfg file and has factory in it).So you may do the following in CLI (just change the file with the relevant one):
# copy flash:/UC560-FXO-K9-factory-8.6.0.cfg start
# wr
# reload
Then you should have connectivity to the UC (default address 192.168.10.1) from your PC and should be able to finish the telephony setup wizard.
Also please check the following:
Before You Begin
Before running the Telephony Setup Wizard
• If the PC running CCA has more than one network interface (for example, a
dual-NIC for wired and wireless network connection), make sure that only
one is enabled.
• Disable any third-party firewall or TFTP services on the PC running CCA.
• Check the firewall and network security settings on your PC to make sure
that TFTP traffic is allowed between the PC and the UC500
• Ensure that the PC running CCA is directly connected to a LAN port on the
UC500 and has obtained an IP address from the UC500 using DHCP.
• Make sure that the UC500 system is at factory default configuration.
• For non-US locales, download and install localization files in the appropriate
location.
• Make sure that you have gathered all the information listed on the Welcome
page of the wizard.
• If the UC500 will be behind an SA500 Series Security Appliance or SR500
Series Secure Router, connect the UC500 WAN to the SA500 or SR500 LAN
before running the Telephony Setup Wizard.
If you need assistance with connectivity please call SBSC to provide such for faster resolution.
Also CCA admin guide is providing a lot of information about CCA and the setup.
HTH,
Alex
*Please rate helpful posts
10-29-2012 02:34 PM
Hello Sam,
# wr
# reload
Before You Begin
one is enabled.
location.
page of the wizard.
HTH,
Alex
10-29-2012 06:36 PM
Thanks a lot! everything works fine by following your instruction!
11-01-2012 04:38 AM
I am glad to hear that everything is OK now.
Thank you for the good rating!
Best regards,
Alex
12-02-2013 09:26 AM
Thanks, I was having the same problem and copying the factory config to startup did the trick. One thing to note is that if you follow the steps you outlined:
# wr
# reload
The "wr" will overwrite the startup config that was just copied with the running config. So if anyone runs into this, leave that part out!
Thanks again!
