10-13-2021 08:39 PM
I am trying to build Webex calling.
When it is necessary to link the head office and branch with SIP,
Can the PSTN perform the SBC function?
PSTN - PSTN_GW - Webex Calling
l
Branch(SIP connect)
Solved! Go to Solution.
10-14-2021 04:44 AM
l
Branch(SIP connect)
This is possible but rather complicated. I'd recommed you to get in contact with an experienced Cisco Partner company in your area. Having Internet SIP trunks and PSTN on the same device can be really dangerous if done wrong.
You can check this document and specifically the part that describes your case
But once again, this can be really dangerous and wouldn't recommend to do it alone if you don't have experience with this.
10-14-2021 04:44 AM
l
Branch(SIP connect)
10-13-2021 09:12 PM
What gateway you use ?
Could you please explain a little more about your setups and requirement ?
10-14-2021 12:49 AM
The equipment
We plan to purchase a module for cisco router and use it as a PSTN gateway.
Can branch office equipment and SIP be connected through PSTN gateway?
The customer asks if the SBC equipment needs to be purchased separately.
