No Call History
Righter8
When I first installed the Webex Windows desktop app it displayed all calls, incoming and outgoing for one day. After a week, it hasn't displayed a single call since.
Any help with identifying how I can reset or check why this is not working would be appreciated.
7 Replies 7
Vaijanath Sonvane
Hi @gstedman ,
Have you tried using Webex App on different PC/Laptop or mobile device? Is it same result?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
gstedman
Same issue.
Reset did not fix.
No history using the portal either.
This is interesting, What version of the WebEx app are you using?
dtibbe
Just fyi: there was an issue with the Webex Calling call history between September 1st and 5th. No PSTN calls were listed in that time frame in the Webex App. Meetings/Calls in Webex were listed.
But as you said it is still not working for you, I'd also think of a client issue.
Does it work via the Webex Web app (https://web.webex.com/)? Do you see your calls in your CUP?
Nope. Thanks though
Vaijanath Sonvane
Hi @Righter8,
Please try resetting your Webex app. In Webex app, click on Profile Picture >> Help >> Health Checker >> Reset (next ot Database Status).
Reset, but difference yet. Let's see if it shows any calls I make or receive...
