liveData reports error on CUIC "Loading view" error
RJ2191993
I have a UCCX 11.6 and CUIC 11.6 (end of support). However, I have an issue with loading live data reports on CUIC
When I tried to run any report, CUIC is enable to display the data and I got the "loading view" error
I tried also reboot the server, but report page stuck in "Loading view..." state
Also, I changed the browser and check if it works, but same error occurred.
Any ideas ?
thank you in advance
mparra.fusionet
Hi@RJ2191993
have a look if your UCCX has the fix for bug belo, it had the same symptoms and it was all the rage due to Chrome changes done in 2018, lots of people that were using browsers Firefox/IE or any Non Chrome based browser were not seeing this issue, only on Chrome based ones.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvj74116
Fix to see if you have installed in your UCCX:
Cisco Unified Contact Center Express (Unified CCX) Release 11.X-CSCvj74116-chrome67 cop file.
https://software.cisco.com/download/home/286314216/type/286315794/release/MultipleRelease_Cops
PJMack
Level 7
Level 7
You should repost this question in a more appropriate category - this is for questions about Webex devices, not Contact Center. Try here: https://community.cisco.com/t5/contact-center/bd-p/5926-discussions-contact-center
