WebEx device conference call
Mark
Is conference call (UCM) supported on WebEx devices like DX80 & room kits? Hybrid calling is activated on mentioned devices.
Stephanie Knoop
Yes, conference calling is supported.  You have to consider all the same conditions as for a regular phone device (conference bridging resources (built in for 3 way, DSPs for multiparty beyond that, codec support, etc.).  From the DX or room kit, instead of a conference button, you select the option to "Add call" and then "Merge".  Let us know if that helps or provide more info as requested above.
Response Signature
Conference calls are supported on DX 80 and room kits.  Could you please explain a little more about your requirement.
Response Signature
