Icons for WxCC Desktop Widgets
vvazquez
where can I see a list ot the available icons to be used ion widgets, when the icon type = momentum? I mean:
"nav": {
"icon": "3d-object",
"iconType": "momentum",
Victor
Arunabh Bhattacharjee
Victor, try these – https://momentum.design/icons
Use the label directly – scroll below in the search area to view them.
Thanks & Regards,
Arunabh.
7 Replies 7
ja.kriventsev
Hi Arunabh Bhattacharjee!
This page (https://momentum.design/icons) is empty or doesn't exist any more.
Could you please provide another one. I tried to use these icons https://momentum-design.github.io/momentum-design/en/tokens/icons/ but webex cc desktop doesn't show almost all of them. for example, Icon "waveform" doesn't exist there.
I have also found that the icons URL doesn't seem to exist anymore. And I also tried the second URL you posted with no luck.
Thanks & Regards,
Arunabh.
Hi, since the URL is still empty at the time I see this post, I found another source that might include all the icons available here:
https://github.com/momentum-design/momentum-design/tree/main/packages/assets/icons
Still not showing 90% of them
You need to change the icontype value in your desktop layout to momentumDesign instead of momentum
It's working now! Thank you! hopefully it will be mentioned in the default layout template:)
