12-13-2023 06:55 AM
where can I see a list ot the available icons to be used ion widgets, when the icon type = momentum? I mean:
Solved! Go to Solution.
12-13-2023 07:19 AM
07-06-2025 05:37 AM
Hi Arunabh Bhattacharjee!
This page (https://momentum.design/icons) is empty or doesn't exist any more.
Could you please provide another one. I tried to use these icons https://momentum-design.github.io/momentum-design/en/tokens/icons/ but webex cc desktop doesn't show almost all of them. for example, Icon "waveform" doesn't exist there.
08-05-2025 02:33 PM
I have also found that the icons URL doesn't seem to exist anymore. And I also tried the second URL you posted with no luck.
12-13-2023 07:19 AM
08-20-2025 06:06 AM
Hi, since the URL is still empty at the time I see this post, I found another source that might include all the icons available here:
https://github.com/momentum-design/momentum-design/tree/main/packages/assets/icons
10-01-2025 04:26 AM
Still not showing 90% of them
10-06-2025 07:08 AM
You need to change the icontype value in your desktop layout to momentumDesign instead of momentum
10-06-2025 07:16 AM
It's working now! Thank you! hopefully it will be mentioned in the default layout template:)
