Can I check the log when a problem occurs while using Webex?
HYEONJIN PARK
If possible, where can I check it?
Hi!
It depends, if your Webex is managed by an organization, you as administrator can access the Control Hub portal and there are the Analysts and the Troubleshooting dashes that allow you to take a deeper look at meeting statistics, user parameters, and so on. I don't know if this answers your question.
