04-05-2019 01:46 AM - edited 07-05-2021 10:12 AM
Hello All,
I have a setup comprising of WLC (8.8.111.0), MSE (8.0.150.0) enabled with WIPS services & CMX (10.5.1).
Since there's already a dedicated CMX (10.5.1), I don't want to enable CAS service on the MSE (8.0.150.0).
The problem with having the CAS disabled on MSE (8.0.150.0) is the maps won't get integrated with MSE at all. Not sure if it is by design or an anomaly.
Generally do we require to enable CAS despite of having a dedicated CMX in the setup?
04-12-2019 06:37 AM
look at this thread
Where Rasika anwers this question:
So that means that the feature to see client location on Prime maps is not anymore supported in CMX?
04-18-2019 01:24 AM
Thanks Pieterh.
This is indeed a major drawback of not having MSE with CAS enabled in the network. This would be required if one intends to see the map location of alarm despite of having CMX in the network
09-04-2019 05:04 AM - edited 09-04-2019 05:08 AM
HI Pierth,
Does not seems to be the case.
On Prime maps, we will indeed be able to see the wireless client locations which are determined by CMX. Please find snippet in the thread i shared:
