To Mobility Express Cisco 8.8.100
Dhikra Marghli
Level 5
Level 5
Hello
I convert from 8.3.111 AP  1815i CAPWAP  to moblity express 8.8.100
But i have a problem :
switch  layer 2 can ping to Cisco mobility express WLC  and my Laptop can pingto  Cisco mobility express WLC
but WLC moblity  express  can't ping   the   switch  ni Laptop and not broadcast SSID and can't get to Web GUI
anyone had this kind of issue with AP 1815i CME?
Urgent ,  i must to resolve this problem So ,
how i can reslove this   CME  that allow  ME ping to switch and laptop and i can get Web GUI   ?????????????
thanks in advance
67 Replies 67
i send yo file version 8.3.111 AP 1815i
if this version can convertir to 8.8.100 or 8.8.111 ???????
if this version can convertir to 8.8.100 or 8.8.111 ??????? to ME ?
cisco AIR-AP1815I-I-K9 ARMv7 Processor rev 5 (v7l) with 1015956/851260K bytes of--More-- memory.
--More-- Processor board ID FGL2221B268
--More-- AP Running Image : 8.3.111.0
--More-- Primary Boot Image : 8.3.111.0
--More-- Backup Boot Image : 0.0.0.0
--More-- 1 Gigabit Ethernet interfaces
--More-- 2 802.11 Radios
--More-- Radio FW version : 8edf74e05d634a962e683454e8fc1be2
--More-- NSS FW version : not available
--More--
--More-- Base ethernet MAC Address : 78:0C:F0:DB:2A:90
--More-- Part Number : 0-0000-00
--More-- PCA Assembly Number : 074-105850-02
--More-- PCA Revision Number : 0
--More-- PCB Serial Number : FOC22195ZNM
--More-- Top Assembly Part Number : 074-105850-02
--More-- Top Assembly Serial Number : FGL2221B268
--More-- Top Revision Number : A0
--More-- Product/Model Number : AIR-AP1815I-I-K9
--More--
Do NOT use 8.3.111.0! That image is only CAPWAP without any Mobility Express function. Use 8.8.111.0 for Mobility Express.
yes i know , if i convertir to 8.8.111  , then i can do acces per interface web !!
i used anthoer  AP1815i to convertir 8.8..11   Bu the AP1815i that i used 8.8.100 , what solution  i can do that , f convertir to capwap ????????,  what i do exactly
i ued a solution :
controller>  I used Backup boot image 8.8.111 and then i convert to 8.8.100 : Then it is fine !!
--------------Show boot---------------
Primary Boot Image............................... 8.8.100.0 (default) (active)
Backup Boot Image................................ 8.8.111.0
But other Problem : i need command to show AP 1815i from CLI  ME 1815 and i need command that allow AP detect WLC 1815  and ME detct AP 1815i
so what command used : please i need you help
i ued a solution :
What command can be used in the controller ME  that AP associated to controller and that  controller associated to acces point????????????,
If both Accesspoints are in the same VLAN, they should discover each other automatically while booting. It's important that a DHCP server is active inside that VLAN.
For this, both AP require the same version, for example 8.8.111.0. If the second AP is running an older version, you need a TFTP server with the correct image.
The manual for this is here:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_cisco_mobility_express_8_8/b_cisco_mobility_express_8_8_chapter_01000.html#task_7EA94A2BAD7D4B0A93A8EBBD000A5DCC
ME  is actually  8.8.100 active and   8.8.111 boot image Backup
ME ( controller ) with 8.8.100
===>  So  other r AP 1815i with  by default 8.3.111 :
if convert 8.3.111 to 8.8.111 that allow ME and AP communicate  ???? or not ???,,
OR  i used other command CLI in ME 1815i that allow AP and ME communicate between them ????
what i can do !!
thanks in advance
what i can do !!
thanks in advance
Ok, if they are running 8.3, you have to first upgrade them. There are 2 types of images that could be running on your 1815i, either a Mobility Express capable one, or one that only is CAPWAP capable.
If it is already running a ME capable image, then this should work by following my previous manual, the chapter " Configuring SFTP or TFTP for AP Join".
Then the AP should discover the Master while it's booting and automatically download the new image from the TFTP server. It must be the same version the Master is running on, so 8.8.100.0 in your case.
But if you ordered CAPWAP APs, without ME image, then you have to follow the process outlined here:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html#id_35615
That means you would first need to convert it to a ME capable image and after that it should be able to join the ME Master.
NO, i want on one  ME 1815I running now 8.8.100 : (  it is ok and it is fine  ) BUT  and other AP ( 29 AP 1815i)   CAPWAPr now running by default 8.3.111
Then , i ask you , what i can do that allow ME 1815I communicate with other AP 1815i and vers versa ???????,
problem 1) what command used in WLC ME ?????? or other method that allow communicaton?
2)Problem 2)  SSID is show in etlehphone but password is not accpted : (  password is the same configure ME ) : seconde problem
there two probleme
so please , what two solution can resolve ????,, ( it must this week finish this project
thanks
Regarding 1,please try a show version on an 8.3.x ap and size me the output. It's possible that the command doesn't exist there.
Regarding 2,what security settings have you configured on the ssid?
1) i send you a file that show version AP1815I new
2) ME 8.8.100 :  i set : username : AP-SOTETEL +  Password : Sotetel123 (  these settings requests when converter from 8.8.11 AP to ME 8.8.100 )
But , i try in pc or telehpne portabl : password don'work !!!
