Prime Installation
latenaite2011
Level 4
Level 4
How long would it take to install a Cisco Prime Installation on a VM with the base software for lifecycle+assurance and maybe add one AP and one switch?
thank you in advance,
LN
d.friday
Level 4
Level 4
Installing Prime on a VM is pretty simple, you can download and OVA file from Cisco, and it basically does all the work for you. Once it's installed it will ask you some basic setup questions.  I would say you can get this installed in an hour.
I hope this helps
David
Ok, thank you!
Installation is easy, true, but configuration can take several hours of getting to know where is what in the menu :)
Oh and the start of the server itself often takes 15-25 minutes, even in small installations ;)
