Wireless access based on device type. BYoD
Anand Thakur
I have a Cisco WLC 2504 ver. 7.4.110 with LWAPs connecting from various global locations through Flexconnect.
I would like to know if we can configure access to network resources based on the devices type like Mobile, laptop and Desktop. Is it possible without ISE or any other product.
How it can be configured?
Does the same WLC model has capability to do this? or We need to upgrade to a different model.
Anand
Vinoth Balu
Hi Anand,
This can be done using local policies.  However, I haven't tested it though.
IOS version - 8.0.110.0
Please find attached screen shot for your reference.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/NativeProfiling75.html
Cheers,
VB
6 Replies 6
Vinoth Balu
Hi Anand,
Cheers,
VB
Hello VB,
Thank you very much for the solution.
One more query is that can we get a list of device types from the controller, which devices e.g. Android or Windows or Apple are connecting to the network. If we get this list then it will be easier to design policy based on the device type.
Anand
Hi Anand,
Yes!
You can get that info from the WLC and please find attached screen shot for your reference.
Cheers,
VB
Hello VB,
i am not getting the device types as my own mobile is showing as laptop in the WLC.
Is there any feature i need to enable?
Anand
Hi Anand,
have you enabled profiling under WLAN?
WLANs> test > Advanced
Local client Profiling
1)DHCP Profiling
2)HTTP Profiling
Also, the below youtube video may help you!
https://www.youtube.com/watch?v=wbauUQ0Wquc
Cheers,
VB
Thanks VB,
I was able to do it. Thanks again.
“Review
