04-24-2023 12:47 PM - edited 04-24-2023 01:57 PM
I have a 140AC and when trying to update the firmware from within the AP UI, I select cisco.com, I get the following error when trying to check for an update:
DNS: IP Address Not Found
The problem is that I cannot find anywhere in the setup to define DNS settings??
Solved! Go to Solution.
04-24-2023 02:26 PM
DNS settings are in Advanced > Primary AP Tools > Troubleshooting Tools. There you can also test name resolution.
04-24-2023 02:26 PM
04-24-2023 03:29 PM
