Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 499 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2794 Views
  • 1 replies
  • 5 Helpful votes
Good morning,I have two question of the design of the wap200e.1) I want to know where are dislocate the 3 internal antennas of the product. I know there is a 1x2 MIMO system (1 Tx and 2 Rx), but where is the right antenna, and where the left on the d...
Hello, A couple of days ago, my old access point burned out. It was a proxim ap-700. Anyway, I bought a new ap and recieve it today. I have been having trouble getting it up and going. I was wondering if anybody might have any idea what I'm messing u...
DrSw1mmer by Level 1
  • 1059 Views
  • 2 replies
The documentation for the 4410N states it supports 802.1x however, all I see is to configure 802.1x using mac address or using uername and password.Does the 4410N support 802.1x using EAP? If so how is it configured? Thanks!!
xjoshx by Level 1
  • 1278 Views
  • 1 replies
Hi!I received my RV180W & started configuring it via web interface.For test purposes I have it connected to a home broadband router (10.10.7.1). I entered a static route in the RV180W which is on the 10.10.10.x. The RV180W WAN port is getting an IP i...
I've got a customer looking to deploy a few WAPs.  I noticed the WDS feature provides seamless roaming.  Both WAPs will be PoE based so I do not need the wireless bridge feature as it seems redundant.  What is the best way to deploy these to present ...
