Hello Shauna,
Issues like this are usually related to the browser your are using, or possibly your anti-virus/security software.
Try opening the page in a different browser. Firefox tends to work the best. I would also recommend checking your firmware to see if it can be updated to support a newer browser.
Since the WAP2000s are a bit older, you can also try as early a version of Internet Explorer as you can find, or running in compatibility view.
Thank you for choosing Cisco,
Christopher Ebert - Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
