Can't Change Password for SSID's any longer!!!
sdixon001
I have 3 Cisco WAP 2000 and have two SSID's set up with passwords. I usually change the passwords every 3 months or so, but now when I log in I can't even see where I can change the passwords. there is no longer a drop down list under Wireless. There actually aren't any drop down lists under any of the Menu items any longer. So weird. Any help is appreciated. Thank you
Shauna
chrebert
Level 4
Level 4
Hello Shauna,
Issues like this are usually related to the browser your are using, or possibly your anti-virus/security software.
Try opening the page in a different browser.  Firefox tends to work the best.  I would also recommend checking your firmware to see if it can be updated to support a newer browser.
Since the WAP2000s are a bit older, you can also try as early a version of Internet Explorer as you can find, or running in compatibility view.
Thank you for choosing Cisco,
Christopher Ebert - Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
