07-27-2023 05:11 AM - edited 07-27-2023 05:30 AM
i have a 150ax that boots up and connects. ssid wlan shows up and clients are connected. the led lights are stuck in green, red, off cycle. when i log into the gui, there are 0 access points (this is the only ap at the moment), there are 0 clients, but the wlan exists. i can verify that clients are connected to the wap and operating normally, but i am unable to make any changes to it since it does not show up under wireless > access points. i left it overnight to see if it would resolve, but after 8+ hours, and a reboot, it is still doing the same thing. any idea how to fix this? i cannot add mesh extenders to a non-existent primary ap.
on a side note, this has been a very frustrating experience setting up this wap, and i have mesh extenders waiting as well. while not a network engineer, i do have a small business stack running in a soho, and i was using a wap581. this should not be this hard to setup.
Solved! Go to Solution.
07-27-2023 12:02 PM
for anyone who gets stuck in this same situation, there are 2 IPs that are needed for the primary AP. one for the hardware itself and another one for the management layer. once the management layer gets an IP, you can go to that IP, and you will see everything. this stops the led green, red, off cycling as well.
07-27-2023 10:17 AM
- Check if the AP is getting sufficient power (through POE or other means)
M.
07-27-2023 12:02 PM
