Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Is the Cisco 2702i series access point constructed and suitable for "Clean Room" (Healthcare environment) so that it can handle the daily chemical cleaning process like the Cisco 3602i and 3702i series access points are constructed to handle?
As title, I want to find a replacement for CBW240AC-E, can anyone show me the above product replacement documentation?
we have inherited a bunch of Aironet AIR-CAP2702E-B-K9 AP'S and need to figure out how to configure and set them up. is there some server level management software for this that we can get a download link for ? I searched and found some note about n...
Hello,I have recently installed a WAP371 access point for a customer. It's the first time I installed this model. When I tested it everything seemed fine, but the customer reports that he very often has problems connecting to the access point and he ...
Hello CommunityI have two Cisco WAP361 Wireless Access Point , How can this scenario be applied?- I take the first device IP 172.16.0.3/23- I take the second device IP 172.16.0.4/23when connect two device such as image , the second device reset the...
Hi everybody! I have a problem in CBW 240AC-G , the led is not blinking any more, it's just light red constantly. no signal from port 2 1G, it doesn't give any act light. I tried to get it into wireless but there is no SSID appeared.I'm trying to upl...
Hello,I've updated my WPA150 from 1.1.0.9 release to 1.1.2.4 and now, when attempting to access management UI it loads the page with Monitor -> Dashboard functionality page selected, but it's kind of darken and in the middle of the page is dialog wit...
Does the CB150-AX, in its factory state, tag its traffic with VLAN ID 1 when it is first configured or is the traffic untagged?I'm trying to configure a CB150-AX with a Juniper EX 2200C and I need to know if I configure a trunk port at the outset, do...
Can anyone confirm what is wrong with Cisco Business Wireless 140AC Access Point (CBW140AC-E)We bought them and for some reason we can’t change them to mesh mode according to the guide https://www.cisco.com/c/en/us/support/docs/smb/wireless/CB-Wirele...
I have been trying to associate a Cisco Testing ID within the Partner Self Service tool, and it has just been spinning for over an hour. I have tried clearing cookies/cache as well as opening up a new screen in Incognito Mode. Is this an issue that ...
142ACM access point stuck blinking amber following 10.8.1.0 update.
Hello i has a Cisco partnership in the past that was cancelled but now i am trying to return to but everytime than i go in the Partner Self service Cisco Registration have an error than cannot allow me to continue, the error is showed in the Screens...
I have a 140AC and when trying to update the firmware from within the AP UI, I select cisco.com, I get the following error when trying to check for an update:DNS: IP Address Not FoundThe problem is that I cannot find anywhere in the setup to define D...
Hello everyone,I created two WLANs ( one for internal use and the other for guest). Tagged each network to an specific VLAN. I can see both SSIDs being broadcasted, but the issue is that the guest SSID is getting the wrong ip addressing , it getting ...
I have a 145AC access point and 3 142ACMs. Above message appears when Cisco Business Wireless App launches. I'm guessing this is caused by the recent change of Bell Giga Modem. 145AC is connected to a Trendnet TPE-TG160g POE switch.
