Facebook WiFi
stevenwilhelm40
I have recently converted 3 K9 access points to standalone, I would like to use Facebook WiFi for people to log-in to them but I'm not sure if this is a supported function for these access point. if anyone could answer this our explain how to do it that would be great.
balaji.bandi
If i understand correctly, you want user to login to wifi using Facebook ID.
if this is correct, then you need to apply a account with facebook for API, and you should have ISE/Radius for guest portable redirection, where you can use Facebook ID as authentication make sense ?
below example  with ISE:
https://community.cisco.com/t5/security-documents/how-to-configure-amp-use-a-facebook-social-media-login-on-ise/ta-p/3609532
BB
Sujoy Paria
You have not mentioned the exact model number of the Access Points. What is the model number?
It seems those are not under Cisco Small Business support category segment.
