Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello everyone,
After a whole lot of testing (years of work!), I think I have finally figured out the best configuration for WAP series. By default they have some problems with Apple devices disconnecting every couple of minutes, with Airplay and so ...
Hello, I have client who uses macbook with an AP CISCO WAP371. the macbook looses the connection randomly. I have follow this link to make setting on wap371 Can you help me to resolve this issue? Gma
Hi All, We have two WAP 150s. I updated one to the latest firmware with no issues when I attempted to update the second it appears that the update was bad. The LED blinks green and reboots every 30 seconds. I was upgrading from firmware version 1.1.0...
Hi all, I would like to configure my wap 121 on an static IP adress type 2.XXX.XXX.XXX / subnet mask 255.0.0.0 in order to work in Art-net protocol.But, the device seams to refuse this type of IP adress, and accept only class C 192.168.xxx.xxx IP adr...
I have a WAP321 installed on a wall bracket inside a closet. I appears to have a HW failure and I am trying to remove it from it from the wall bracket. It is locked to the bracket, and I can't move it in any direction to pull it out of the bracket. I...
I have an AIR-LAP1262N-E-K9 (bought second hand) and I want to convert it into autonomous. I learned that needed is file : ap3g1-k9w7-tar.153-3.JD17.tar from https://software.cisco.com/download/home/283307705/type/284180979/release/15.3.3-JD17And ...
Hi all,
I've come across something strange where the WAP371 will not show any neighboring 5Ghz networks, even though I know for a fact that there a quite a few around. Both 2.4Ghz and 5Ghz radios are on, but when enabling Rogue AP Detection, all I ...
I made a firmeware upgrade of my WAP150 from 1.1.0.9 to 1.1.1.0. The webiterface showed the succesful upgrade and was rebooting the device. After that, the green led was blinking for hours and AP was not available on the network. After power off and...
Hi All, I am getting high latency in my AP. Please suggest how I can reduce this. With WIFI : Ping statistics for 10.71.1.6:Packets: Sent = 46, Received = 45, Lost = 1 (2% loss),Approximate round trip times in milli-seconds:Minimum = 1ms, Maximum = 6...
Hello friends.I have several AIR-AP1852I-E-K9 and AIR-AP1562E-E-K9 administered centrally in a controller configured in one of AIR-AP1852I-E-K9. Specifically the AIR-AP1562E-E-K9 they are attached with two AIR-ANT2547VG-N antennas connected connecte...
Hello engineers .I have three APs, two WAP150 and one WAP125.WAP125 reports right client wireless types (b/g, n, a, ac).But WAP150's status screen reports only b/g or a for n,ac clients.And one of WAP150 does not reports traffic graph. 1. WAP125, it ...
I replaced my WAP371 wireless APs with 2 WAP581 APs. If I make a Wi-Fi call and roam between WAP581 I seem to get a 1 second drop. My test is I call my wife using iPhone7 and 7Plus. She is on 1 WAP581 and I am on the other WAP581. If I walk over...
Hi,We have 3 Cisco WAP561 in a cluster. It worked at the begining of the implementation.A few months ago it started having issues. The signal is good, devices can connect successfully but either no internet at all or very slow and unstable speeds. T...
- AP1 Model : WAP581-A-K9 V01 Firmware Version : V1.0.2.0 - AP2 Model : WAP581-A-K9 V01 Firmware Version : V1.0.2.0 - AP3 Model : WAP581-A-K9 V01 Firmware Version : V1.0.2.0 Three wireless APs suddenly go off at an unexpected time.No records ar...
Dear Community, I have a strange issue that I never seen before on my career.My WAP581 freeze entire network of my company during startup.The switch where clients and the WAP581 are connected is a NETGEAR GS748TS (a stack of 3).Model is WAP581-E-K9 V...
