11-28-2013 06:19 AM
After going through the wizard and setup a new password, what is the username I should use? The wizard does not allow to input username.
HELP!!!
Solved! Go to Solution.
01-23-2015 12:04 PM
After finishing the wizard you should have changed the password but the username will remain the same, so when you try to log into the unit the next time you should use cisco as the username and the new password that you just changed during the wizard
If that is not working, you will have to reset the wap and start again.
To reset the wap make sure that it is turn on and hold the reset button for over 30 seconds, then it should go back to the default settings and you can log back into it by going to 192.168.1.245 and entering cisco/cisco as your credentials.
I hope this helps
11-28-2013 06:49 AM
And i'm also having dificulties doing the "reset to factory default" routine. Reset button for more than 10 seconds not working.
01-23-2015 12:04 PM
I hope this helps
03-31-2015 03:00 AM
I got it to work. It was actually working all along. The problem was with Internet Explorer's inconsistent behaviour.
Use chrome.
03-31-2015 05:52 AM
I am glad to hear that. Thank you for letting us know and for telling what you did to resolve. That will help other who may run into the same issue.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
01-23-2015 03:42 AM
Please refer to the following post:
https://supportforums.cisco.com/discussion/11752746/cisco-wap-321
