Wireless Access Points Hooked up to RV320
antonpham03
We have a office network setup to support up to 20 staff.  I'd like to add wifi access to our office network and looking for a reliable Wireless Access Point that can be plugged directly into the RV320 without additional controllers or hardware in between.
We've looked at the Aironet 1700 & 2700 and unsure if these models work directly with the RV320 without additional controllers.  Does anyone know first hand?
http://www.cisco.com/c/en/us/products/wireless/aironet-1700-series-access-points/index.html
http://www.cisco.com/c/en/us/products/wireless/aironet-2700-series-access-point/index.html
Ingrid Aragon
Thanks for contacting Cisco, let me share with you the contact information to a specialized department that can provide you the accurate information to your inquiry, find below the contact information.
Get Presales Help
Michiel Beenen
Level 3
Level 3
Hi, you might wanna look at the WAP300 series (for example WAP 371), these should work perfectly fine for your use case. However, to power them you would still need a power adapter with each access point or put a simple SG100 POE switch in between RV320 and the WAP AP's ;)
Arun Thomas
I would say WAP361/571 should be good enough for you. Both of them need POE+ power source. Instead of  POE switch you can use Cisco power injector - SB-PWR-INJ2-xx.
