Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 844 Views
  • 1 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2975 Views
  • 1 replies
  • 5 Helpful votes
I was told that the Surface Pro would run Cisco AnyConnect.  I would like to know if anyone is using this on their Surface and if there were any issues in installing.  I haven't yet tried to download it wanted to hear some opinions first.
kkomatsu by Level 1
  • 1543 Views
  • 0 replies
Hi Cisco Community We have 2 x WAP121 connected to a SF-100-16 ports POE. The  throughput on Wireless is only 34mbps, with a client conencted with N-wireless adaptor The internet connection is 350mbps Is it what we can expect from the Wireless throu...
I purchased a new WAP571-A-K9 V01 which is having issues with PoE.  When I connect the WAP to our new Aruba 2920-48G-PoE+ switch on port 3/17, I receive the following error when logging into the web console for the WAP: The power source of WAP device...
joneill70 by Level 1
  • 974 Views
  • 0 replies
We have an office with 50 users (80 devices) and 2 WAP561 Access Points in cluster mode.  We're finding the network slow at times and would like to upgrade so devices can connect at higher speeds and access points that can handle higher loads.  We're...
james1333 by Level 1
  • 1533 Views
  • 3 replies
