1131 AP12.4(3g)JA & 5508 V. 7.2.103
Hello Guys me Again I have some questions about this AP and it's IOS. I have some AP's 1131 and they have IOS 12.34(3g) JA I'm working with a 4402 WLC I'm going to change this WLC for one 5508 but this WLC has a different version software it has 7.2.103. My questions is I need to do any upgrade to my AP's IOS for join to the new WLC ?
I found a compatibility Matrix, in this document I guess i nedd to do some upgrade:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
But I was checking this link
The WGB can be any autonomous access point that supports the workgroup bridge mode and is running Cisco IOS Release 12.4(3g)JA or later releases (on 32-MB access points) or Cisco IOS Release 12.3(8)JEB or later releases (on 16-MB access points). These access points include the AP1120, AP1121, AP1130, AP1231, AP1240, and AP1310. Cisco IOS releases prior to 12.4(3g)JA and 12.3(8)JEB are not supported.
This part of the document make me guess I don't have to do anything.
anyone knows if I really need to do an upgrade?
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
21 Replies 21
I don't need a minimun version of IOS on my AP's to join at the WLC 5508 ?
The only "minimum" version is the RCV lightweight IOS to enable your AP to find and join a WLC.
Hello Scott.
There is the show version:
------------------ show version ------------------
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(3g)JA, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 27-Apr-07 01:56 by pwade
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
CORCIR099-P2TI01 uptime is 1 week, 1 day, 59 minutes
System returned to ROM by reload
System image file is "flash:/c1130-k9w8-mx.124-3g.JA/c1130-k9w8-mx.124-3g.JA"
cisco AIR-AP1131AG-N-K9    (PowerPCElvis) processor (revision B0) with 24566K/8192K bytes of memory.
Processor board ID FTX1446N03Z
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 4.1.171.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 58:8D:09:EA:B4:C8
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC14431NRC
Top Assembly Part Number             : 800-29230-02
Top Assembly Serial Number           : FTX1446N03Z
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1131AG-N-K9
Configuration register is 0xF
Scott Fella
Table 4 of the matrix is what you want to look at.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp81600
-Scott
Scott Fella
Your fine. This is how you can tell if the image is autonomous or lightweight.
C1130-K9W8-M
K9W8 is capwap
K9W7 is autonomous
-Scott
thank you Scott
No problem... Here is a support doc that explains it better:)
https://supportforums.cisco.com/docs/DOC-19607
-Scott
No problem.
-Scott
