1310 Bridge RG-59 coax cables.
darrenj
Hello all, hope everyone is well.
The RG-59 coax cables that come with the 1310 bridge are only 1 foot long. Does anyone know where I could get longer cables as the power injector is quite a distance away because there are no close power sockets. Instead of installing new power sockets near to the bridge, we wanted to simply run longer coax cables.
Hope someone can help!
sethgarnar
Cisco also sells a 100 foot cable. You can go up to 300 feet on the coax. We ended up buying a spool of coax and some ends and made our own.
The roof mount kit come with long cables also
fredn
This cable is standard CATV (cable/dish antenna cable) type RG-6 that is commonly available at any radio or entertainment store - It is exactly the same cable that is used to go from the cable TV receiver to the television - Raw cable and connectors are available from places like Home Depot, Lowes, Walmart etc.
Fred
