2100 Wireless LAN Controllers
ricardorojas123
Level 7
Level 7
In the WLC 2112, I can connect Access Points in the available port.
For example:
WLC Port 1 --> Connected to Switch (802.1Q)
WLC Port 5 --> AP vlan 50 (access mode)
WLC Port 6 --> AP vlan 50 (access mode)
WLC Port 7 --> AP vlan 50 (access mode)
Surendra BG
Hi ,
Its works but not supported by TAC and not recommended as well.. please refer the doc authered by lee johnson..
https://supportforums.cisco.com/docs/DOC-11760
Lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Surendra BG
Hi ,
Surendra
Surendra BG
