2602AP's Won't Register with 5508 Controller
dgood1234
Hello everyone -
We have a 5508 controller that manages AP's at approximately 20 branches - each branch has their own subnet. We have a single branch (subnet) with new 2602 AP's that will not register with the controller. All communications to this subnet appear normal and there are no ACL's in place between the AP's and the controller. The AP's are able to resolve the controller IP address via DNS and begin the registration process but then timeout. We have successfully installed 2602 AP's at other branch locations and they register with no problems - this is only a problem at a single branch. I've attached some debug messages below for a single AP (this is a production environment so I parsed un-necessary info) and also included the console messages from a different AP (the console messages on the AP's are the same). There are currently 9 AP's at this location and none of them will register. Any ideas??
Debug Capwap Events:
*spamApTask0: Dec 11 14:39:32.904: 44:2b:03:9a:d1:10 Discovery Request from 10.29.9.190:44306
*spamApTask0: Dec 11 14:39:32.904: 44:2b:03:9a:d1:10 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 300, joined Aps =272
*spamApTask0: Dec 11 14:39:32.904: 44:2b:03:9a:d1:10 Discovery Response sent to 10.29.9.190:44306
*spamApTask0: Dec 11 14:39:32.992: 44:2b:03:9a:d1:10 Received LWAPP DISCOVERY REQUEST to 68:ef:bd:8e:48:6f on port '13'
*spamApTask0: Dec 11 14:39:32.992: 44:2b:03:9a:d1:10 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask0: Dec 11 14:39:42.903: 44:2b:03:9a:d1:10 DTLS connection not found, creating new connection for 10:29:9:190 (44306) 10:5:13:4 (5246)
*spamApTask0: Dec 11 14:57:52.301: e8:ba:70:dc:d1:c0 DTLS connection closed event receivedserver (10:5:13:4/5246) client (10:29:9:190/44306)
*spamApTask0: Dec 11 14:57:52.301: e8:ba:70:dc:d1:c0 No entry exists for AP (10:29:9:190/44306)
*spamApTask0: Dec 11 14:57:52.301: e8:ba:70:dc:d1:c0 No AP entry exist in temporary database for 10.29.9.190:44306
*spamApTask0: Dec 11 14:57:53.828: 44:2b:03:9a:d1:10 Discovery Request from 10.29.9.190:44306
*spamApTask0: Dec 11 14:57:53.828: 44:2b:03:9a:d1:10 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 300, joined Aps =272
*spamApTask0: Dec 11 14:57:53.828: 44:2b:03:9a:d1:10 Discovery Response sent to 10.29.9.190:44306
*spamApTask0: Dec 11 14:57:53.916: 44:2b:03:9a:d1:10 Received LWAPP DISCOVERY REQUEST to 68:ef:bd:8e:48:6f on port '13'
*spamApTask0: Dec 11 14:57:53.916: 44:2b:03:9a:d1:10 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask0: Dec 11 14:58:03.824: 44:2b:03:9a:d1:10 DTLS connection not found, creating new connection for 10:29:9:190 (44306) 10:5:13:4 (5246)
Debug Capwap Errors:
*spamApTask0: Dec 11 15:17:33.715: e8:ba:70:dc:d1:c0 Deleting AP 10.29.9.190 which has not been plumbed
*spamApTask0: Dec 11 15:17:33.716: e8:ba:70:dc:d1:c0 DTLS connection was closed
Debug Capwap Details:
*spamApTask0: Dec 11 15:24:29.419: 44:2b:03:9a:d1:10 CAPWAP Control Msg Received from 10.29.9.190:44306
*spamApTask0: Dec 11 15:24:35.542: 44:2b:03:9a:d1:10 CAPWAP Control Msg Received from 10.29.9.190:44306
*spamApTask0: Dec 11 15:24:41.555: 44:2b:03:9a:d1:10 CAPWAP Control Msg Received from 10.29.9.190:44306
*spamApTask0: Dec 11 15:24:49.555: 44:2b:03:9a:d1:10 CAPWAP Control Msg Received from 10.29.9.190:44306
*spamApTask0: Dec 11 15:25:29.420: 44:2b:03:9a:d1:10 CAPWAP Control Msg Received from 10.29.9.190:44306
*spamApTask0: Dec 11 15:25:29.420: 44:2b:03:9a:d1:10 DTLS connection 0x1a1703c8 closed by controller
*spamApTask0: Dec 11 15:25:29.421: CAPWAP DTLS connection closed msg
AP Console log:
Translating "CISCO-CAPWAP-CONTROLLER.ad.pps.k12.va.us"...domain server (10.29.8.3)
*Mar  1 00:00:57.511: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP. [OK]
*Mar  1 00:01:10.511: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec  11 16:05:56.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
*Dec  11 16:06:17.495: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560E-24PD (68bc.0c03.8015)
*Dec  11 16:06:28.231: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2051 Max retransmission count reached!
logging facility kern
% Invalid input detected at '^' marker.
logging trap emergencies
*Dec  11 16:06:55.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.5.13.4:5246
*Dec  3 16:06:55.999: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec  11 16:07:06.367: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec  11 16:07:07.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
*Dec  11 16:07:39.151: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2051 Max retransmission count reached!
*Dec  11 16:08:06.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.5.13.4:5246
*Dec  11 16:08:06.999: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec  11 16:08:17.367: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec  11 16:08:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
*Dec 17 15:53:47.463: %CAPWAP-3-ERRORLOG: Selected MWAR 'IRC-WLC-5508'(index 0).
*Dec 17 15:53:47.463: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 17 15:53:47.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
*Dec 17 15:54:23.131: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2051 Max retransmission count reached!
Getting alot better.
The WAP has selected the 5508 with the correct firmware.  The WAP sends a JOIN Request to 10.5.13.4 but cannot get anything back.
Firewall?  Routing loop?
This so-called "remote site", how is it connected back to your office?  Dark fibre?  ISP?
Y'know what?  Can you post the output to the following commands:
1.  WAP:  sh inventory;
2.  WLC:  sh sysinfo
Nuts, I should've asked for these info before.
30 Replies 30
Scott Fella
You running 7.2.110.0 or higher.  That is what is required for these AP's.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp97700
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Yes, we are running 7.3.101.0. Also note we have other 2602 AP's that have registered with this controller and are working properly.
Well... it does seem like something is blocking udp 5246 & or 5247.  I would take a good AP that has joined and put it out on that remote site to test.  If that AP doesn't join, then something is indeed blocking.
Scott
-Scott
Scott - that is my next move. I have an AP here that has already joined and I hope to have it on site later today. Will post any findings / results.
Let us know what you find.
Scott
-Scott
OK - I registered a new 2602 AP with the controller at our central location, then moved it out to the branch site with the problem. The access point will not join the controller from the remote site even though it joined before I took it out. A parsed portion of the cosole log is below:
*Mar  1 00:01:23.819: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 13 19:39:26.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
*Dec 13 19:39:58.131: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2051 Max retransmission count reached!
*Dec 13 19:40:25.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.5.13.4:5246
*Dec 13 19:40:26.059: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec 13 19:40:26.199: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Dec 13 19:40:26.199: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Dec 13 19:40:26.451: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 13 19:40:26.471: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
I have not run any debugs on the controller since taking this AP on site but I would guess the messages are similar to the original posting. Thoughts??
Post the entire bootup process.
So you have H-REAP/FlexConnect enabled on the WAP?
Below is the entire boot process on the AP that joined from our central location, but now won't join at the remote site. Yes, we have H-REAP/FlexConnect enabled on one of our WLANS - although it isn't currently in use.
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 37 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 18247680
flashfs[0]: Bytes available: 13750272
flashfs[0]: flashfs fsck took 18 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 44:2b:03:9a:dd:00
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.152-2.JA/ap3g2-k9w8-mx.152-2.JA"...#########################
File "flash:/ap3g2-k9w8-mx.152-2.JA/ap3g2-k9w8-mx.152-2.JA" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
flashfs[0]: flashfs fsck took 8 seconds.
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.152-2.JA/ap3g2-k9w8-xx.152-2.JA;flash:/ap3g2-k9w8-mx.152-2.JA/ap3g2-k9w8-xx.152-2.JA'
Loading "flash:/ap3g2-k9w8-mx.152-2.JA/ap3g2-k9w8-xx.152-2.JA"...############################
File "flash:/ap3g2-k9w8-mx.152-2.JA/ap3g2-k9w8-xx.152-2.JA" uncompressed and installed, entry point: 0x2003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.2(2)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 23-Aug-12 02:29 by prod_rel_team
Initializing flashfs...
flashfs[3]: 37 files, 9 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 31997952
flashfs[3]: Bytes used: 18247680
flashfs[3]: Bytes available: 13750272
flashfs[3]: flashfs fsck took 9 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 12257280
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 12256256
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present 8764 8000 0 A8000000 A8010000 0
Rate table has 244 entries (64 SGI/104 BF variants)
Radio1  present 8764 8000 0 88000000 88010000 4
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2602I-A-K9    (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FGL1640Z00A
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.3.101.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 44:2B:03:9A:DD:00
Part Number                          : 73-14588-02
PCA Assembly Number                  : 800-37899-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16337KKT
Top Assembly Part Number             : 800-38356-01
Top Assembly Serial Number           : FGL1640Z00A
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP2602I-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:10.231: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:13.723: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:17.287: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:23.543: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:25.867: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:25.867: %SNMP-5-COLDSTART: SNMP agent on host TestAP1 is undergoing a cold start
*Mar  1 00:00:26.299: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:26.299: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:26.439: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:26.915: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:29.827: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed
*Mar  1 00:00:29.827: DPAA Initialization Complete
*Mar  1 00:00:29.827: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:30.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:54.815: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:57.867: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:58.963: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:59.911: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.29.8.163, mask 255.255.248.0, hostname TestAP1
*Mar  1 00:00:59.963: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:00.055: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:01.055: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:01:10.839: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP. [OK]
*Mar  1 00:01:13.843: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'IRC-WLC'running version 7.0.98.0 is rejected.
*Mar  1 00:01:13.843: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:13.843: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:13.843: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:13.843: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.5.13.3
*Mar  1 00:01:23.839: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 14 13:07:43.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
*Dec 14 13:08:19.131: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2051 Max retransmission count reached!
*Dec 14 13:08:42.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.5.13.4:5246
*Dec 14 13:08:43.063: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec 14 13:08:43.199: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Dec 14 13:08:43.199: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Dec 14 13:08:43.451: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 14 13:08:43.471: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 14 13:08:43.475: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'IRC-WLC'running version 7.0.98.0 is rejected.
*Dec 14 13:08:43.475: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Dec 14 13:08:43.475: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Dec 14 13:08:43.475: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec 14 13:08:43.475: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.5.13.3
*Dec 14 13:08:44.199: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec 14 13:08:44.231: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Dec 14 13:08:44.239: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec 14 13:08:45.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec 14 13:08:45.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec 14 13:08:45.259: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 14 13:08:45.267: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec 14 13:08:45.275: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec 14 13:08:46.259: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec 14 13:08:46.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec 14 13:08:46.295: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 14 13:08:47.295: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec 14 13:08:53.467: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 14 13:08:53.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
*Dec 14 13:09:29.131: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2051 Max retransmission count reached!
*Dec 14 13:09:52.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.5.13.4:5246
*Dec 14 13:09:53.059: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec 14 13:09:53.199: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Dec 14 13:09:53.199: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Dec 14 13:09:53.447: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 14 13:09:53.459: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 14 13:09:53.467: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'IRC-WLC'running version 7.0.98.0 is rejected.
*Dec 14 13:09:53.467: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Dec 14 13:09:53.467: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Dec 14 13:09:54.199: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec 14 13:09:54.231: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Dec 14 13:09:54.239: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec 14 13:09:55.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec 14 13:09:55.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec 14 13:09:55.259: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 14 13:09:55.267: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec 14 13:09:55.275: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec 14 13:09:56.259: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec 14 13:09:56.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec 14 13:09:56.295: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 14 13:09:57.295: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec 14 13:10:03.459: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 14 13:10:04.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.5.13.4 peer_port: 5246
Thanks for the logs.  Very useful.
So what's this?  The WAP is trying to join a controller (IRC-WLC) with a 7.0.98.0 code.  I think this could be the issue.
Yea, i was following the thread and that stuck out for me as well ..
Was this AP joined to another WLC or did you have another WLC in this controllers mob group ?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Cann't connect to AP 2602I to WLC 5520
           %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.10.5:5246
*Jan 24 22:11:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.10.5 peer_port: 5246
*Jan 24 22:11:48.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2214 Max retransmission count reached for Connection 0x896C710!
Please let me know if you have a answer to solve this issue.
First, create a completely new thread.
and paste the output of these commands:
sh version from AP
sh sysinfo from WLC
Also paste the complete boot-up process from AP console.
Dont forget to rate helpful posts
Scott Fella
Didn't see it, but I'm assuming the AP did get an ip address?
Moving the AP from a location in which it was able to join to another location and then the AP fails to join means that UDP 5246 and or UDP 5247 is being blocked. Check to see if it might be blocked going out or coming back. Since you know it's a good AP.
-Scott
I put a sniffer inline and can confirm that traffic from the AP in question is reaching the controller on UDP port 5246 but I see nothing on UDP port 5247. At what point would traffic start on UDP 5247? I'm checking ACL's and so far I have found nothing. Our WAN is managed by our ISP and I am having them check any ACLs they may have in place as well.
