08-28-2014 12:11 PM - edited 07-05-2021 01:27 AM
I currently have a 2602i access point that I need to load autonomous image ap3g2-k9w7-tar.153-3.JAA.tar on to, with no WLC. I have already tried the steps from the following links...
https://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/discussion/11875096/convert-2602i-lightweight-autonomous
Each time I have tried I am hooking my laptop running tftpd32 to the Ethernet interface on the AP. I have been using 10.0.0.5/24 and/or /27 as the IP for my laptop/tftp server. When doing the steps that say assign an address to g0 I have tried both 10.0.0.1 and 10.0.0.2/24 or /27.
I am at a loss and hoping that there is an answer out there that is specific to the 2602i that I have not found yet. Each time I go through any of the steps the connection to the tftp server times out. I have adjusted the time out setting in tftpd to 30, 45 and 100 seconds.
Thank you in advance
-Dave
Solved! Go to Solution.
12-22-2020 05:27 AM
12-23-2020 04:17 AM
yes i do it so.
Laptop is connected to a PoE Injector and this is connected to the AP.
PCI-Express Card with com port is connected to the Console port.
IP from Laptop is 10.0.0.2 255.255.255.0
Firewall is off at Windows, Wifi also off.
image is in a folder at the desktop, i rename it to ap3g2-k9w7-tar.default
I power off the ap and start holding Mode Button
Power on
LED is blue
start flashing blue
goes red
release button
flashing green
error opening path
flashing red
here the screen
cu
12-23-2020 07:34 AM
12-23-2020 01:06 PM - edited 12-23-2020 01:39 PM
No i can´t ping them.
Nothing at the tftp
Show file extension is on
at tftp
timeout i have 30 sec
max Retransmit 60
tftp port 69
tftft Security: None
12-23-2020 04:10 PM
12-27-2020 02:15 PM - edited 12-28-2020 09:36 AM
Problem was the PoE Hub it don´t work correct.
Now i use a normal PoE Injector.
I can flash, but i don´t have a actual firmware.
So i try to configure.
Is there a howto to configure?
Problem i can´t connect to the internet and the SSID are not visible
12-28-2020 01:35 PM
Works now, thanks to all
At the Event Log i got this messages is this normal or something wrong?
Time Severity Description Mar 1 04:37:49.182 Warning Packet to client 98f4.abb8.d973 reached max retries, removing the client Mar 1 04:37:49.166 Information Interface Dot11Radio0, Deauthenticating Station 98f4.abb8.d973 Reason: Sending station has left the BSS Mar 1 04:37:39.438 Warning Packet to client 98f4.abb8.dc4c reached max retries, removing the client Mar 1 04:37:39.430 Information Interface Dot11Radio0, Deauthenticating Station 98f4.abb8.dc4c Reason: Sending station has left the BSS Mar 1 04:37:36.582 Warning Packet to client 84f3.ebe5.c52f reached max retries, removing the client Mar 1 04:37:36.574 Information Interface Dot11Radio0, Deauthenticating Station 84f3.ebe5.c52f Reason: Sending station has left the BSS Mar 1 04:37:23.038 Information Interface Dot11Radio0, Station 98f4.abb8.d973 Associated KEY_MGMT[WPAv2 PSK] Mar 1 04:37:19.170 Warning Packet to client 98f4.abb8.d973 reached max retries, removing the client Mar 1 04:37:19.166 Information Interface Dot11Radio0, Deauthenticating Station 98f4.abb8.d973 Reason: Sending station has left the BSS Mar 1 04:36:39.898 Information Interface Dot11Radio0, Station 98f4.abb8.d973 Associated KEY_MGMT[WPAv2 PSK]
01-30-2021 10:24 PM
Step by Step Process has been demonstrated How to of Convert Cisco Aironet 3600 Series Access Point from Lightweight to Autonomous version.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
Requirements:
1.TFTPd64 Server
2.Cisco IOS Software AP3G2-K9W7-M for (C3600 Series AP)
3.The Cisco AP and the Laptop with TFTP server must be in same network.
According to my network setup
Lightweight AP BVI1 IP address is 192.168.1.4
Laptop's IP address where TFTP server is installed 192.168.1.7 [Default Router IP]
First disconnect the ethernet cable from the AP then Press the Mode button and Put back the ethernet cable to the AP and hold the Mode button Untill flash light turns to umber and Once the Lightweight AP goes to online then apply the following commands to convert it to Autonomous version:
set IP_ADDR 192.168.1.4 [According to my network setup]
set NETMASK 255.255.255.0 [According to my network setup]
set DEFAULT_ROUTER 192.168.1.7 [According to my network setup]
tftp_init
ether_init
flash_init
tar -xtract tftp://192.168.1.7/ap3g2-k9w7-tar.153-3.JH.tar flash:
dir flash
set boot flash:/ap3g2-k9w7-mx.153-3.JH/ap3g2-k9w7-mx.153-3.JH
set
boot
