2802E with internal antenna, when external antenna is plugged in does it disable internal ?
janit
Hey, I've seen minimal cost difference between the 2802e with or without internal antenna. For flexibility is it possible to disable internal when external antenna is plugged in, or perhaps it's automatic ?
Scott Fella
2802e does not have internal antennas, only the 2802i. So when you choose an access points, you need to decide if an external antenna is required for better coverage or internal is better. That will make the decision on if you choose an ‘e’ or an ‘I'.
-Scott
Scott Fella
-Scott
janit
Oopsie, right. I think my current 3502 have that option. Can't believe I missed that point. Thx
