3502e directional antenna connection
choclateer
                   The 3502e has 6 antenna connections, 3 for each band, 5GHz band is marked in blue. The antenna pigtails are only marked with the matching color - 3 blues or 3 blacks. No A,B or C. Does it matter which pigtail goes to which of the 3 terminals so long as the band is correct?
Scott Fella
Depending on the antenna, just match up the middle pigtail for the blue to the middle port of the 5ghz (blue) radio. Then do the same for the 2.4ghz (black). The outer ports doesn't matter.
-Scott
