3702i and 9800 WLC AP join issues
georgehewittuk1
Hi All,
Just running into a few issues with a lab and wondered if anyone had seen this before. The AP is trying to join the 9800 WLC but is getting the following message.
*May  5 12:19:28.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.100.0.22 peer_port: 5246
*May  5 12:19:28.299: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.100.0.22 peer_port: 5246
*May  5 12:19:28.299: %CAPWAP-5-SENDJOIN: sending Join Request to 10.100.0.22
*May  5 12:19:33.299: %CAPWAP-5-SENDJOIN: sending Join Request to 10.100.0.22
*May  5 12:19:33.319: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.100.0.22
*May  5 12:19:33.319: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.100.0.22:5246
Not in Bound state.
The AP is running the latest code for the 3702i and the WLC is running the last supported code 17.3.5a (to my knowledge).
George
7 Replies 7
docjb0221
17.3.5 was very buggy. I’d try 17.3.6.
17.3.6 solved that problem but unfortunately hit another issue this - https://community.cisco.com/t5/wireless/ios-xe-17-9-3-has-been-released/td-p/4795844
https://quickview.cloudapps.cisco.com/quickview/bug/CSCwd80290
So anyone that googles this worth just going to 17.9.3
I would not be wasting any more time with 17.3.X (for 1700/2700/3700/1570 support).
Upgrade to 17.9.3 and start testing that.
Absolutely second that - avoid 17.3, go direct to 17.9.3 (or later) for wave 1 AC APs.
Compatibility matrix shows Cisco IOS XE Amsterdam 17.3.x is the last support for 2700/3700 series. I see you mentioned 17.9.3, do you know if the AP works with it?
I have >4k x 3700 still hanging around 9800 controllers on 17.12.4.
NOTE:
Due to "pressures" from some big customers, 2700/3700 support was re-introduced from 17.9.3 and the last firmware will be 17.12.X.  2700/3700 will not be supported from 17.13.X onwards.  However, IW3700 will still be supported from 17.13.X onwards.
ISEe
Appreciate your quick feedback. Will give 17.12.4 a try with my 3702i.
Thank you sir!
