3800 not showing WLANs
DavidStammler
Upgraded the lab controller to 8.2.130 to test some 3802i's we got. Access points come up fine, but WLANs don't broadcast (or even show up). Put a 2602 on there and it works fine, test WLANs broadcast and we are able to connect. For some reason the 3802s just aren't working. Any ideas?
Sandeep Choudhary
HI,
Is the SSID/WLAN configured to use TKIP?
Please note that TKIP is not supported yet with the 3802 AP's. If this is configured, the SSID will not show up. Check this link for more info:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_01100.html
Dont forget to rate helpful posts
Sandeep Choudhary
HI,
wow, that did it! we had wpa/tkip and wpa2/aes on the wlan, i never thought to disable tkip (knowing that it wasn't supported). Thanks!
Great. Thanks for rating.
