3802 Mobility Express not discovering 3802 AP
Ahmed Mostafa
Hello
i bought 14 APs model is 3802 , 2 of them is mobility express but when i started the mobility express it is not discovering the other APs
Thank you for any help!
10 Replies 10
 According to Cisco docs, this model does not appear as possible subordinate Access Point. Only as Master.Screenshot_2017-09-16-23-31-25.jpg
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/83/user_guide/b_ME_User_Guide_83/about_mob_exp.html
Hi Flavio
So do you have any idea how to fix this issue
I see two option. Install those 14 APs as standalone mode or buy a small WLC and convert those AP to CAPWAP. WLC 2504 is a very good option.
Many thanks Flavio
Hi Ahmed
Have You checked the os version of the APs ? It should be the same with the master AP.
All master AP can be Subordinate AP.
1 year has passed. Is the model 3800 not yet supported as a subordinate?
Is there any solution other than how to install a controller for these access points, for seamless communication?
Hi Sunin
Every Master APs can be used as a subbordinate.
Just convert the AP image to the latest (8.4 or 8.5 as of now)
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8_4/b_cisco_mobility_express_8_4/b_Mobility_Express_Deployment_guide_chapter_0100.html
Skip 8.4 right away and go directly to 8.5. 8.4 will not be further developed.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8_4/b_cisco_mobility_express_8_4/b_Mobility_Express_Deployment_guide_chapter_0100.html.
