3802 PoE Power draw.
JASON SIMMONS
Level 2
Level 2
How much power are your 3802 access points drawing from your PoE switches?  Are they Cisco switches?  We have an installation of 3802s connected to a non-Cisco 802.3at enabled switch and we're seeing a maximum 11w to each AP.  A consultant was expecting to see somewhere between 15-25w.  It appears that all the radios are up but users have been complaining about peformance and connectivity since they were installed.
26 Replies 26
Scott Fella
12W on a Meraki switch. No issues with connectivity.
-Scott
I learned and configured the switch to statically assign 30W and I'm still getting 11.x watts, although I saw it jump to 13w once.  Cisco TAC basically said it isn't compatible and told me to buy an injector...
I honestly don't know if power is the problem.  I just know installing the older switches worked.
I don't know...
Thanks for your replies.
No, it's a bug with the AP software.  It seems that AP is having difficulty negotiating power if it's not Cisco.
I believe TAC would say that "it's not supported".
Power should not be a problem… Mine changes to up to 13W and drops down also.
-Scott
Disable CDP on Juniper if it's enabled.
It's possible that Juniper is bringing a wrong PoE budget information via CDP.
Juniper does not support CDP.
Just checking. Was this ever resolved?
No we never determined root cause.  We replaced the APs.
derobbacher
our 3802i show the same behaviour in power consumption on our Cisco SG350-10P switches:
On Port gi1 is a 3802i using only 10,8 Watt and on Ports gi2-gi4 3 old Cisco 1142-APs are connected.
Unit Module Nominal Consumed Temp SW PSE chipset
Power (W) Power (W) (C) Version HW Revision
1 SG350-10P 62 57 (92%) 73 23.190.18.3 PD69208 - 0x4A02
Interface Admin Oper Power (W) Class Device Priority
gi1 Auto On 10.800 4 low
gi2 Auto On 9.600 (15.400) 3 low
gi3 Auto On 11.500 (15.400) 3 low
gi4 Auto On 10.300 (15.400) 3 low
The show cdp nei detail reveals also the Full/Half-Duplex-Mismatch Bug with the new Csico 2800/3800-series-APs:
Device-ID: D20-HVT
Advertisement version: 2
Platform: cisco AIR-AP3802I-E-K9
Capabilities: Router TransBridge
Interface: gi1, Port ID (outgoing port): GigabitEthernet0
Holdtime: 114
Version: Cisco AP Software, ap3g3-k9w8 Version: 8.3.141.0
Copyright (c) 2014-2015 by Cisco Systems, Inc.
Duplex: half
Primary Management Address: IP 10.232.4.193
Addresses:
IP 10.232.4.193
But cdp does not show any info about the Power drawn.
The WLAN AP and the antennas are working.
We are not sure about any restriction on WLAN AP functionality.
I fear that maybe special functions like beamforming will not working with only 10 Watt.
But I'm not sure.
Does anyone know if this is a nice power-saving-feature or a bug with the Cisco 3802-APs?
Thank You
Wini
derobbacher
One can see that the nominal value in brackets () is missing for the 3802-AP in comparision to the old 1142-APs:
Device-ID: D20-HVT
Holdtime: 114
Duplex: half
Addresses:
IP 10.232.4.193
But I'm not sure.
Thank You
Wini
Have a read here: https://www.cisco.com/c/en/us/support/docs/field-notices/702/fn70252.html It seems you should upgrade to 8.3.150.0 or newer.
Regarding the power, you have a 60 W budget, of which ports 2-4 already use a lot. You actually already use 92% of available power, not enough for the 3800 left.
