5508 management ips
lcaruso
Level 10
Level 10
I'm trying to reach a 5508 via a vpn connection but cannot connect I assume because there are management ips set on the box somewhere. I just logged into another 5508 to see where that setting exists, but cannot find it.
Is that setting on the 5508 itself. If so, where?
Thanks.
3 Accepted Solutions
Abha Jha
kaaftab
Level 9
Level 9
Do check the reachability as connecting with VPN does not affect the  access to the AP, provided that no ACL or restriction is  applied to the  management IP.
Saurav Lodh
Level 11
Level 11
Enter  show interface detailed management command to view the current management interface settings from CLI. To enter the management interface ip using config interface address management ip-addr ip-netmask gateway
Abha Jha
Please go to controller and interface tab to get the mangemnet IP:-
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60mint.html
kaaftab
Level 9
Level 9
Saurav Lodh
Level 11
Level 11
