5508 WLAN config help
dclee
Need help with the following config..
I currently have one 5508 controller that is configured with 2 WLANS..one is a guest WLAN and the other is used by internal clients
via authentication back to our AD. This all works fine.
In total there are 32 AP's that broadcast both of these WLANS. Ideally I would like only a subset of these AP's to broadcast both WLANS as I have 10 AP's in a public area that only need to broadcast the guest WLAN.
Am I able to configure which WLANS each AP can broadcast ?
Cheers
Dave
Stephen Rodriguez
yes.  The feature you need to look into is call AP Groups
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
