8.10.105 and WPA3
timgrantham
Is anybody else using the MobilityExpress 8.10.105 with WPA3 enabled?
I'm getting an annoying thing happen where clients are booted every 24 hours and take an age to reconnect, which when you have AppleTVs streaming can be annoying as they drop and then report incorrect password for ages when trying to connect back...same happens with other devices on connecting via WPA3..
WPA2 is fine - if I disable WPA3 then the devices will remain connected and not drop.
I understand that this is an initial release, and could have "caveats" in the build OS, I'm currently testing at home as my client is wanting to go WPA3 ASAP due to security concerns and the nature of their business, so I'm the guinea pig...
This is more of a case to find out if anybody else is experiencing this, or am I the only one??
7 Replies 7
AlexW22
I guess I am experiencing something similar. When I enable WPA3 on MobilityExpress 8.10.151 my apple devices (iPhone/iPad) don't connect to the AP at all. Because of this I also ended up using WPA2. Is there any additional config required to set up WPA3? I am using an 3800 AP.
Here is a matrix that will show what is supported
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc64463741
-Scott
Yes, PMF needs to be set to enabled. Then you also need to select the right combination of supported key exchanges.
Did you make a pure WPA3 ssid or a mixed one? I would start with a pure WPA3 one to test.
I have the same problem. AIR-AP2802I-E-K9 / 8.10.151.0 with a WPA3 Personal only SSID. All clients can connect, but not the iphones.
How can I enable PMF ?
I also see this in the logs:
ASSOC_REQMESSAGE_RECEIVED
ASSOC_REQINVALID_RSN_IE
PEM_EVENT_MSGIP_ACQUIRED_AND_AUTH_NOT_REQ_OR_STATIC_DYNAMIC_WEP_SUPPORTED
ASSOC_REQCLIENT_MOVED_TO_ASSOCIATED_STATE
AUTH_DOT1XWLAN_REQUIRES_802_1X_AUTH
EAPOL_KEYUNABLE_TO_ALLOW_USER
MISC_ROAM_EVENTS
MISC_ROAM_EVENTS
AUTH_RESNOT_FROM_RELAY
EAPOL_KEYRETRANSMITTING_EAPOL_KEY
MISC_ROAM_EVENTS
EAPOL_KEYIDENTITY_PACKET_RECEIVED
Volker
Would you please elaborate on PMF? What is it and can it be set in Mobility Express? I was turning off WPA2 functionality for the SSID. So the answer your question its a pure WPA3 SSID. To my knowledge you can only create a WPA2 network through the Mobility Express gui and later edit it to turn off WPA2 and enable WPA3 Personal. But I was using one enabled at a time. On WPA2 everything works as expected. On WPA3 iPhones don't connect.
I suggest having a read here: https://mrncciew.com/2020/08/17/wpa3-enterprise/
I have checked the PMF (802.11w) status on the controller AP through the CLI with:
config wlan security pmf required <wlan-id>
OUTPUT:
Already in requested state.
So it appears that Mobility Express Controller sets this automatically in the background when toggling on the WPA3 function
