8.3MR2 Beta Availability
rutvshah
Release 8.3.114.74 Beta (8.3MR2)
We are pleased to announce Beta Refresh Release for 8.3MR2.
Please Register at below link to participate in the Beta Program. Once Registered a separate Email will be received with Software Download Link.
http://cs.co/83MR2Beta
8.3.114.74
Resolved Caveats
Identifier Headline
CSCvb05067 Local EAP fails after wrong username login
CSCve01552 Unknown Username when switching from open to dot1x SSID
CSCve13183 AP2800/3800/1800 WCPD Crash with clients connected and can't recover after crash
CSCuz47559 error saving config file happens on multiple 2702
CSCve34143 Wlan-vlan mapping not working sometime when ap removed and added back in flex grp
CSCvd20251 DP stopped working on 5508 running 8.0.140.0
CSCvb93365 WLC msglog showing a lot of traceback
CSCvd72432 LocalEAP LDAP Request With Incorrect Password Lockout Users
CSCve05840 Addition of DP show commands as part of show run-config
CSCvb74948 AVC - CISCO-JABBER-IM application is getting misclassified as SSL
CSCvd36259 ME Controller intermittently Flaps with external AP.
CSCvd96491 SR: Rest/API for WLC exposing Assurance login password
CSCux11777 1532 non-root bridge high retransmission and latency rate
CSCvb62874 Radio interface Input queue gets filled on Autonomous APs.
CSCvc49713 AP generates flood of Received and decoded a DMS client request payload SUCCESSFULLY
CSCvc81929 Mobility Express crashes when DHCP screen is accessed
CSCvd58113 wlc allowing telnet and ssh over ipv6 on global telnet and ssh disabled
CSCvd66657 AP 3802: SensorD stuck in offchannel causing radio stops working
CSCvd90117 AP3800 - Radio crashing frequently due to beacon stuck
CSCvd92166 Couldn't pass host testie build in the branch 8.3 mr throttle in richardson ads, but can pass in sjc
CSCvd99909 8.3 MR2: AP 3800 - 5G Radio crashes - when SI enabled
CSCve07524 In GUI 11ac config behavior mismatch with CLi for different AP mode
CSCve06701 Client stuck in DHCP_REQD on flex AP after changing native vlan
CSCvd43728 Ap1850 DTLS Teardown after channel change
CSCve18484 Clear data icon is not working if other languages like korean,japanese is selected in browser
CSCve13073 MC9090 doesn't join with 11g disabled
CSCve01109 SXP connection on WLC stays off.
CSCve21379 During Auto Provisioning Feature, Radius Server Templates are getting applied but staying Disabled.
CSCvc44293 8.4 - ME UI - Changing Transmit power on UI does not work
CSCvd67178 Anchor not deleting webauth req client beyond webauth timeout
CSCve09531 v6udp_csum_buf overshooting the buffer resulting in WLC crash
CSCvc81082 Polaris XOR: The radio is updated as UP whenever AP's XOR band is configured eventhough POE is low
CSCve17730 Kernel panic seen due to wlTxDone in 8.2.151.7
CSCux97132 AP starts CAC timer after rolling back to lower bandwidth
CSCvd53205 DCA lists in RF profiles are broken after backup/restore the WLC's config
CSCvd87065 WLC crash due to task nmspTxServerTask
CSCve17355 Upgrade to WLC - 8.3 software enables 11k & 11v by default on all WLANs
CSCvc41484 Corsica: high failure rate in off-channel operation, QCA 2721453
CSCvc86951 AP1850 beacon miss/corruption during downstream traffic test, QCA 02793762
CSCvc98310 AP 1830: 2.4-GHz radio stopped working @0x009915D7, QCA 02797962
CSCvd18732 AP 1810 radio FW Assert @0x0099B2DA in overnight multi-client test, QCA 02818890
CSCvd28594 Client association fail after altering data rates in AP 1830.
CSCvd28645 AP sending RTS at 6 data rate when data rate 6 is disabled, QCA 02829301
CSCvd77037 AP1832 sending instant ACK after CTS that block data from client, QCA 02862955
CSCve00464 AP1852 detects high noise level on 5-GHz radio for every channel except the serving one
CSCve10751 Clients cannot assocate with AP after changing from DFS to non-DFS channels during CAC, QCA 02910240
CSCvb57350 SNMP trap for "AP Interface Up/down Traps" not getting generated.
CSCvd69782 Roaming L3 test was failed with 50% in Talwar and Pata WLC
CSCvd80962 8.3MR2: LWAPP-3-AP_LOCK_ERR traceback observed on WLC for AP2800/3800 AP
CSCvd81926 CCX Proxy arp flag not set in IOS APs
CSCve08894 Unable to debug VRRP issues unless have devshell access
CSCvb70551 COS AP's rebooted due to Kernel Panic-Not Syncing: Out of Memory
CSCvc81429 8.2MR5: AP3800 throughput drop in client scale test with random client MAC addresses
CSCvd61747 AP3800: Radio crash due to off channel stuck due to defer_chchange_flag always set to TRUE
CSCvd91894 3800/2800 kernel panic crash PC is at mv_dev_kfree_skb+0xc/0xa4 [ap8x]
CSCvd96867 Sanity: radio1FW core found in ap1560 with 8.4.2.52
CSCve14081 AireOS: Same channel has been assigned to both the 5Ghz Radios after capwap restart
CSCuw45964 Mobility Express: While Editing a WLAN in HTTP session ,user is getting logged out
CSCvd37808 8510 WLC stopped working - iappSocketTask
CSCvb04932 APs not discovered because of wrong bsnAPIfType returned for 1810W
CSCvd06463 AMSDU packets tx cause 5sec gap of packet tx to 8821 from IOS AP
CSCvd44446 Retried EAP Response Dropped as a duplicate while First EAP Response was not even received on the AP
CSCve30199 CCKM PMK (Version 2) message flooding 8.3MR2
CSCve23103 AP3800: False RADAR detection without RADAR source
CSCve23874 BARBADOS-Client got associate immediately even if CAC timer start on AP log ,when DFS channel is set
8.3.114.57
Resolved Caveats
Identifier Headline
CSCvc67005 2802 AP drops client ARP packets after web authentication
CSCvc08052 DFS false detection on AP2700
CSCva90265 iPAD PRO with IOS10 is getting deauthenticated at times due to M3 timer
CSCvc86170 ClickAP FlexConnect Local Auth doesn't work on WLAN with CCKM security
CSCvd85995 AP3800:AP deauth client after roaming and doesn't send deauth when client sends qos null
CSCvd18773 8.2 clients unable to authenticate 'Sending assoc-resp with status 12 station'
CSCvd90669 Need support for AAA override w/ MAC filtering on RLAN
CSCvd79597 Smart License 5520/8540 : Unable to reset HTTP-Proxy on Call home configuration from GUI
CSCvd70755 AIR-AP3802I crash due to kernel panic
CSCvc49492 AP1852 detects high noise level on 5-GHz radio
CSCvd56581 Client not getting IP address when moving between SSID
CSCvd14806 APs randomly not showing any neighbors on both radios
CSCvd97103 IPv4 CPU ACL - IP-Address with netmask other than 255.255.255.255 doesn't work
CSCvd98548 Kernel panic inside ForwardFrame function!
CSCva17630 WLC sends warm-start trap instead of cold-start during autoprovisioning
CSCvd54154 All AP1850 connected to master AP crash in a loop due to watchdog reset
CSCvd86274 1800/2800/3800 Series AP does not send the Platform value via CDP when it is brand new
CSCvc74876 8.2.145.21: Barbados CAPWAP disconnect then stuck in discovery loop
CSCvd91770 Trust-DSCP-Upstream broken on 8.2.151.0
CSCvd88630 AP 3800: Ap crash due to 'wcpd' in 8.4
CSCve01859 With FIPS enabled on 5520WLC, 3802AP shows no 5Ghz neighbors
CSCvc82845 WLC returns nothing for SNMP get WEB ACL - cldcClientAaaOverrideAclName
CSCvd36736 AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second
8.3.114.44
Resolved Caveats
Identifier Headline
CSCvd40646 AP2802 - Kernel Panic - Dot11Classifier: Mgmt frame not supported 0
CSCvd69992 AP: 2800/3800 unable send proper sequence# and burst rate upstream
CSCva44397 WLC gateway not reachable after disabling LAG
CSCvc15976 Trustsec: AP: Not able to enable/disable AP inline tagging and SGACL Enforcement via SNMP
CSCvb54392 3800: MacBook Pro Clients with OS X 10.11 getting stuck in DHCP_REQ
CSCvd46216 AP1832 sometimes does not send authentication response
CSCvd46314 Standalone COS AP should reject new client if MAC auth is configured
CSCvd72664 1850 AP sometimes tags 802.1q vlan for native WLAN, causing ARP packet drop
CSCvd74063 AP1832 Crash due to watchdog reset(wcpd no heartbeat)
CSCva26821 Auto Anchor Deployment: Scheduling deletion of Mobile Station fails
CSCvb77390 WLC stopped working accessing MAC Address Database
CSCvd32632 Standby Controller stopped working @rmgrReboot
CSCvd42348 Standby WLC stopped working on performing SNMP Set on bsnDot11QosProfileEntry
CSCvc85164 11k: WNM neighbor report is empty in when WLAN ID is greater than 1
CSCvd61977 2800/3800 -radio coredump generation may stuck ca_status leading to IPC call function failures
CSCva33212 Re introduce auto provisioning feature on WLC 2504 running 8.0
CSCva46506 Flexgroup RADIUS configurations are not pushed to AP
CSCva84030 Increase CLI WLC username and password to 128 char for TACACS support.
CSCva88600 Evaluation of WLC for TCP August 2016
CSCvb71600 WLC stopped woking after applyng CPU ACL
CSCvc40852 82MR4. Active controller in HA pair shows different socket errors
CSCvd50044 System stopped working multiple times on ping rx task
CSCva88319 5508-HA-WLC stopped working with Task Name: TransferTask
CSCvb64042 WLC HA transfer download failure with legitimate network latency
CSCvb93189 AP drops Retransmitted M3 from WLC
CSCvd15742 AP crash with %ENTROPY-0-ENTROPY_ERROR: Unable to collect sufficient entropy
CSCvd83741 AP: 1850 unable send proper sequence# and burst rate upstream from AP to MSE
CSCvd30952 RM3010L-B-K9 Hyperlocation Module stopped working
CSCvd81303 2800/3800: Limit 'best' DCA to 80 MHz also for RF profiles
CSCva14667 GET on Ap groups Table after set - response missing
CSCvc94648 Evaluation of wlc for OpenSSL Jan 2017
8.3.114.36
Resolved Caveats
Identifier Headline
CSCvd24540 SNMP System crash when tried to create tunnel with clGatewayTunnelEntry MiB
CSCvd19354 WLC crash while editing config rf-profile hsr-mode disable | enable config rf-profile 11b
CSCuz47786 FlexConnect AP sending IGMP report to WLC for local switching WLAN
CSCvb86157 clients can't connect anymore to vWLC- Instrumented code added
CSCvc67465 Flex AP loses vlan mapping if vlan tagging is enabled.
CSCvd37960 83MR2-clients getting re-anchored if critical application is present on client
CSCvb64560 CISCO-LWAPP-AAA-MIB: DEFVAL format incorrect for some objects
CSCvb67724 5508 is going out of memory
CSCvb69962 Client traps not showing session ID's
CSCvb98859 AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second
CSCvc52210 After reboot of the Master AP, CMX connector service has to be disabled/enable for Test link to work
CSCvd33140 ME 8.4 - Constant increase in WLC Memory reaching 90% and above
CSCvd35988 8.5 5520WLC-HA causing DENY rule on WLC and Telnet&Gui access down
CSCvb20553 Coa for session timeout not working using free radius server
CSCvb53368 validate rogue clients against AAA not work
CSCvc11630 Radio reset in switching to connected mode from standalone
CSCvc24485 #APF-3-UNKNOWN_RADIO_TYPE: [SS] apf_utils.c:571 Unknown Radio Type 0 from Standby flooding syslog
CSCvc65675 WLC: Constantly increasing memory consumption by SNMPTask
CSCva72390 8.4.1.27 - Corsica in Bridge intermittently stalls show commands ...
CSCvc03468 2800/3800: Packets not beamforming with beamforming enabled.
CSCvc49263 RLAN-VLAN mapping misconfigured after moving to secondary
CSCvc55328 AP crash due to kernel panic at WlLoadRateGrp
CSCvc86979 2800 AP silent reboot with NUL print every 10 mins continuously
CSCvc93398 AP2800/AP3800 MU-MIMO forms MU groups with 2SS clients
CSCvc95222 1810w LAN port dropping IPTV packets when wired device is 100M(QCA 02835075)
CSCvd20271 Ap 3800 crash 8.3.104.131 in Monitor mode with wips submode
CSCvd27285 ME_1852E : CCO image download re-initiated on the APs on which the Dwnld was alrady completed
CSCvd29564 Layer 2 Packet Drop Of CDP Packets for COS APs
CSCvd35231 AP1810W: Reload Reason: 0: Unknown aka Silent Reboot
CSCva99545 Invalid information displayed in show cert webauth/webadmin
CSCvb45130 Part of ATF config is not pushed to uploaded config
CSCvb62478 Wlan is allowed to be enabled when FT enabled without FT-psk/FT-802.1x
CSCvc61652 m25/1.0 is shown in client info
CSCvc63169 Flex AP specific WLAN-VLAN Mapping lost on rebooting the AP
CSCva99052 Configuring 1810W to OEAP does not enable DHCP on Local port LAN3
CSCvb29996 1810W Hardware Watchdog reset crash PC=0xc03b3ffc, LR=0xc008af24, QCA 02698633
CSCvb54306 1815: LED blikning green - light green even at full power and clients connected
CSCvc07184 Media streaming behavior different between 1560/3800 and 3700
CSCvd20843 Beacon stuck due to off-channel stuck
CSCvd21051 AP3800: Kernel crash at wlTxDone+0x190/0x688 [ap8x]
CSCvd51674 AP1810W: Silent reboot : revert highest power table value
CSCva81406 WLC - Unmap deauth reason codes 13-22 from reason code 15 exclusively
CSCva92917 Observed Traceback logs in show msglog and logging
CSCvc83583 5520 controller crashed with taskname apfProbeThread
CSCvc87433 Webauth with proxy doesn't work after 8.2
CSCvc88997 FRA probe suppression config not saved after WLC reboot
CSCvd01586 WLC crash - Task Name: RRM-DCLNT-2_4 | rrmClientCoverageHoleAlgorithm
CSCvd05332 After changing AP mode to FlexConnect, AP does not assign IP to RLAN clients
CSCvd06848 crash SNMPTask Reason:System Crash
CSCvd07423 AP firmware corrupt after power cycle bad mzip file, unknown zip method reboot loop
CSCvd15404 Rule creation with CLRuleConfigEntry crashes the controller
CSCvc07521 AP3800 sends A-MSDU larger than client can handle
CSCvd25231 Collect Stack info for silent reboot of 2800/3800
CSCvd33219 AP 3800: FW hang detected - chatter: wl1: fwHangDetect(357): FTR!
CSCuz16883 Address registration issues for mobility scenarios
CSCva68921 WISM2 reaperWatcher got stuck on DP0 while retriving crash and crashed
CSCva77707 AIR-CT5508 SSO ARP request out redundancy management sent with wrong MAC
CSCva79367 Cannot add or delete Syslog Servers To WLC
CSCvb44979 WLC Local EAP with 7925 Handshake Failure
CSCvc04089 2700 series AP radio resets reason code 71 RADIO_RC_NO_REPORT
CSCvc12594 Controller fails to send SNMP when using untagged interfaces on different ports
CSCvc78510 2702 aux port goes to disabled after the ap is rebooted
CSCvd53765 After restarting WLC NMSP goes down on CMX
CSCuz70879 MAP reloads on hitting 40 mins timer even when it is downloading image
CSCva06617 8.3Beta :Globally configured ATF mode not applied to newly joined AP2700
CSCva20342 WGB uses incorrect MAC while trying to setup BA
CSCva31890 MIB table bsnMobileStationPerRadioPerVapTable has no data
CSCva39537 802.11h configuration not saved after restoring config backup
CSCva40580 8.3:BulkSync on active wlc never completes and is stuck in 'in-progress'
CSCva83802 HA: SSH on redundancy management interface rejected
CSCva91483 AP2700 failing co-channel fairness with Samsung S5
CSCvb11778 8.1.131.18 WLC crash on sisfSwitcherTask
CSCvb48354 RRM Not updating as per configured on WLC
CSCvb57779 APs unable to join WLC in different subnet through gateways with proxy-arp disabled.
CSCvb61023 DHCP Option 82(remote-id) not present is some AP
CSCvb81940 Vlan tagging for external module removed from Ap after upgrade to 8.3.102.0
CSCvc39231 SNMP GETBULK on cLIpsecProfileTable returns with No response from controller
CSCvc68156 Full support for "distance" on AP1572
CSCvc79811 When adding/removing country codes 2.4GHz channels change
CSCvc83490 Redundancy Mobility MAC does not stay, Primary WLC's MAC is always set instead
CSCvd09240 Local-auth EAP-TLS win10 not working
CSCvc62277 5520 crashes on running rrm commands on task emWeb
CSCvc85328 AP1832/1852: Power injector/Normal mode inspite of power supply by AIR-PWR-C
CSCvd15394 3800 AP will reject login for login credentials with childer ~ in password
CSCuz77859 Flexconnect: AP specific DHCP-NAT-PAT config does not apply in the WLC
CSCvb12026 Client Load Balance export to Anchors Fails with New mobility enabled
CSCvb51570 WISM 2 crashed on upgrade to 8.3.102.0 with Task Name: spamApTask6
CSCvb89781 2700-B AP unable to join WLC: Unable to create temp dir "flash:/update"
CSCvb97383 WLC deauthenticating roaming client with idle timeout
CSCvc33793 WLC tears down connected AP due to unequal loadbalance between SPAM queues high load
CSCvc83175 VWLC does not learn client IP / Client stuck in DHCP_REQD
CSCvd00067 wired WGB client is removed from parent AP's association table
CSCvd18025 anchor1 wlc does not free client sessions after client roaming to anchor2 wlc-client entries stale
CSCvd21155 WLC Crash when multicasting traffic and accessing WLC GUI
CSCvd21969 AAA AVC Override - AVC profile retained after roaming
CSCvd41350 83mr2-8500 crash osapiReaper fatal condition at broffu_fp_dapi_cmd.c:4574
CSCvd56671 WLC Crash : Task 'apfMsConnTask_0' in 8.3 MR2
CSCvc94524 2800/3800 iphone & android phones are not getting ipv6 addresses
CSCvd00289 2800/3800 capwapd init unsuccessful creating 2 capwapd causing WCPD watchdogd reset
CSCuz45986 CWA not working on 8500 as Guest anchor with Accounting enabled
CSCva66176 AP drop of from Network due to large set of Mobility groups in down/down
CSCva95121 Stale IP route left on Flex AP config if booting up in standalone mode
CSCvb13666 WiSM2 crash with Task Name 'IPv6_Msg_Task'
CSCvb15871 aIOS not forward broadcast multicast frames with dynamic vlan
CSCvb16806 5500 MC showing stale connections from MA clients
CSCvb33076 WLC: GUI does not allow to change sniffer channel
CSCvb96009 WLC Crashed on emweb task on 8.3.102
CSCvb99468 AirOS WLC crashed in emWeb when serving an EmWebForm exclusion-list
CSCvc66352 5500 controller crashed with taskname emweb
CSCvc74515 8.2.121.11/8.2.124.15 : WLC Data plane crash due to fragmentation
CSCvc78546 WLC sets Zero 11e QoS for downstream voice traffic when CAC is disabled
CSCvd39346 2800/3800 WCPD slow memory leak
CSCvd49909 Kernel panic @ ClientCapabilitiesTracker virtual address invalid
CSCvb91652 PMIPv6 Sluggish cli/gui response as well as sporadic lack of snmp response
CSCvc23724 WLC crash with EoGRE Heartbeat and skip count configured with value 0 which makes tunnel dead
CSCvc65568 8821 fails 11r FT roam with "Invalid FTIE MIC"
CSCvc82053 The nmsp info/probe notification queue is saturating
CSCvc82376 EAP-TLS certs and PMK cache are missing on Flex AP after reload
CSCvd12057 Flex AVC : Downstream QoS marking not working - 8.3
CSCvd56064 Flex local switching, local auth not supported when PMF is enabled in 8.3.114.22
CSCvd61701 SSH to Standby RMI or Service port Fails
CSCuq05475 Controller GUI shows AP's NAT IP instead of private
CSCvb12565 WLC stops working when running 'show run-config' command with no APs
CSCvd48333 Controller stopped working : emWeb
CSCvd63242 Click AP not associating with 11r client in flex connect mode
CSCux83260 BGL-Alpha: "lbs-ssc" &" sha256-lbs-ssc" missing in WLC web UI
CSCva85361 WLC losing IPv6 Connectivity
CSCvc41438 WGB running 15.3(3)JD WGB takes ~500ms longer to scan DFS channels vs JBB
CSCvb35865 AP2800 crash for flexconnect-Sensor-Flexconnect
CSCvc83465 8.3MR1: 3800 AP sometime stops sniffing on DFS channel
CSCva64515 %SPECTRUM-3-CA_LOGMSG: SPECTRUM LOG: invalid radio type
CSCvc40267 WLC sends wrong VLAN for AAA overriden client re-associating to AP belonging to FlexConnect Group
CSCvc74507 Fix incorrect commit of CSCuu59589 in 8.0-mr
CSCvd27065 EAP-FAST EAP-Chaining on Wired 1810W port does not work
CSCvd58664 AP dropping EAP packets on Radio which is seen on Wired uplink
CSCvd56422 Error cause 403 generated for 'RFC-3576 Disconnect-Request'
CSCuz03702 New mobility:Wired client behind WGB fails to pass traffic after roaming
CSCva66489 11r sess timeout after reassoc causing Deauth 17 mismatch FTIE
CSCvb94413 2800/3800: Fix DAA
CSCvb97656 Unexpected reload: Task Name: mmListen on 8.3.102.0
CSCvc28168 WLC set ZERO 802.11e QoS UP for part of the downstream voice packets and APs trust it
CSCvd06993 Upgrade to 8.3 requires to reconfigure DNS server IP
CSCva49263 802.11r re-auth failure after roaming
CSCvb05494 Wrong format of SNMP trap - mobility flap alarm
CSCvc09824 AP2800 band select stats counter show zero
CSCvc18670 WLC: Client stops passing traffic on DHCP Reqd. WLAN after sending a Reassoc request but no DHCP pkt
CSCvc50436 WGB wired client randomly stuck in the DHCP_REQD state after layer 2 roaming between the controllers
CSCvc52093 WLC send deauth 17 to phone in 4-way handshake
CSCvc65641 WLC reports tracebacks reported very frequently but no crashes
CSCvd07215 AP1810/2800 doesn't learn DHCP lease time from DHCP server and defaults to 24hr.
CSCvc12566 New transfer upload command for uploading bundled  wlc log files
60 Replies 60
There is another bug, at least in my environment, which wasn't there with 8.2.
Every time the DCA algorithm ran the same process crashes after it finished channel changes. The crash doesn't influence the cluster or traffic, it just happens with 8.3 and it happens always. Maybe it's related to the false information collected from the 1262 APs?
Beginning of Crash File: mwar_rad_deadlock.crash
* Start Cisco Deadlock Handler *
Version: 8.3.114.57
Timestamp: Tue May 9 00:00:14 2017
Mscb Index: 79
So, what's the right way to give feedback to beta if not here?
Thank you and regards,
Chris
Hi Christian
check the wlc uptime, it should not be changing. This is quite probably CSCvd81902, which is fixed on next code refresh
(no impact)
regards
Hi Javier,
thank you for your reply. Do you mean uptime on wlc landing page? This is counting up as expected: Up Time 8 days, 1 hours, 39 minutes
I'll wait for the next code refresh and come back with new findings if it's ok for you?
Christian
Installed 8.3.114.74 right now but still no data for 1262 APs:
Model / Domain
AIR-LAP1262N-E-K9 / 802.11bg:-E 802.11a:-E
Power status
DC / Full Power
Serial Number
FCZxxx
Groups
AP Group: testgroup, Flex Group: default-flex-group
Mode / Sub-mode
Local / Not Configured
Max Capabilities
No Radio 2.4GHz & 5GHz
Spatial Streams : 0 (2.4GHz), 0 (5.0GHz)
Max. Data Rate : 0 Mbps(2.4GHz), 0 Mbps(5.0GHz)
Christian
kdavison007
Will CSCvd84189 be resolved in this release?
That defect is not resolved (it is waiting for test data). it is suspected to be solved on this release, pending confirmation
Any news about vWLC + FlexConnect Central Switching?
al.genery
I was wonder if there had been any progress on Monitor mode APs running wIPS sub mode on the 3802 model.  I have had them crash (its less now with 8.3.114.57) occasionally as soon as we enable 2.4 GHz on the wireless controller.  (Wireless tab --> 802.11b/g/n --> network --> enable)
Its usually about one crash an hour.  There is a TAC we have open for this issue but we haven't heard much in regards to the status on this lately.
smartitbg
Is this bug CSCve00464 affects 1832 APs? We have exactly the same problem - "high noise level on 5-GHz radio for every channel except the serving one".
https://quickview.cloudapps.cisco.com/quickview/bug/CSCve00464
yes, 1830/1850 share same radio implementation, so defects would apply equally to both platforms
regards
OGB
Hey Javier
is there a way to download the images without installing that godawful Aspera software? I can't open any ports or install applications on my work computer.
Flo
Hi Florian
unfortunately, the shares server uses that protocol for fast download (it is hugely faster than the previous upload server), and the file and total folder size limits are significantly larger than previous solution, plus the file storage is encrypted, etc.
so, it was a small price to pay to get a better supported repository
if you need access to  specific files, please let me know, and we can help to store on the previous location
Are the two bugs that caused 8.3.111.0 to be deferred included in 8.3.121.0? I don't see it listed in the entries of CSCvd23510 or CSCvd48226, or conversely those bug ids in the release notes for 8.3.121.0
hi
Bug fixes are accumulative, those two are fixed in 112.0, thus also included in 121.0 and any future 8.3  release
As they are already documented in the 112.0 release notes, we do not include or mention explicitly on the new release notes for later releases
regards
