802.11n 2.4Ghz data rate vs connection speed
KevinR99
Level 3
Level 3
I'm trying to understand data rates vs connection speed with a 11n client.  In my Cat9800 I have 11Mb/s disabled, 12Mb/s mandatory and 9 and 18-54Mb/s supported.
I have a client connected with 2 spatial streams at 144Mb/s
And in the client details they are connected at MCS rate m15
Am I connected at 36Mb/s and the connection speed with 2 spatial streams is 2 x 36 Tx added to 2 x 36 Rx ?
Is there anywhere that shows the actual rate I am connected at.
Also, the above rates come from the RF tag.  If I look in the Radio configuration - Network - 2.4Ghz area I see
What's the difference between that and the RF profile rates of
Thanks as usual for any input.
Kev.
Refer https://mcsindex.com/  to understand the expected data rates.
Here is a good article explaining how to read mcs index table - https://wlanprofessionals.com/mcs-table-and-how-to-use-it/
Radio configuration - Network - 2.4Ghz settings are global. These apply to AP with default RF Tag.
However, if you've set up an access point with a customized RF tag (profile), the RF tag settings will supersede the global settings and be applied specifically to that access point.
Jagan Chowdam
/**Pl rate useful responses**/
Rasika Nayanajith
6,9,12,18,24,36,48,54 Mbps are OFDM rates (knows as legacy data rates) and HT(11n)/VTH(11ac)/HE(11ax) rates are known as MCS (Modulated and Coding Scheme) data rates.
In WiFi you got 3 types of frames
1. Management frames (goes only on primary 20MHz, use one of those legacy rates)
2. Control frames (goes only on primary 20MHz,use one of those legacy rates)
3. Data frames (use bonded channel-20/40/80/160MHz and use one of MCS rates )
If you want to work out rate of a 'data frame' you need to refer that MCS table. Note that your client throughput is much lower than data rate value, which is normal.
Rasika
*** Pls rate all useful responses ***
