01-31-2020 09:04 AM - edited 07-05-2021 11:38 AM
I have a Cisco 5508 wireless controller that I'm using on my test Network. I'm having a connectivity problem with the 5508. I have completed the initial configuration on the 5508. My Management Port is Port 1 on the 5508. I'm using a CAT5 SFP adapter on Port 1 of the 5508 with an IP address of 192.168.5.250. The other end of the cable is connected to a 2960 PoE switch on gigabitethernet0/2. Both interfaces are up, but I can not ping the 5508. I am pinging the 5508(192.168.5.250) from the domain controller(192.168.5.7). What configuration do I need to make so I can connect to the 5508? I have included 2 screenshots.
Thank you.
Solved! Go to Solution.
02-03-2020 03:55 AM
02-03-2020 03:55 AM
02-14-2024 08:50 AM
I have same problem with my switch 2960 and wcl 5508
i changed config but problem not resolve
can u help me ?
thks
