802.11r Fast transition for FT and non FT devices
tbnguyen
I'm trying to find a sort of on-size-fits-all solution for our production network for different customers, on a central C9800 cloud WLC.
A feature I would like to enable is 802.11r for Fast Transition, which from testing has worked well in environments with a homogenous device group. And in cases where one client doesn't support it, we can recommend a replacement, since it most likely is old and has expiring warranty.
But now I want to include customer environments where you can find all sorts of devices old/new, with/without support for 802.11r.
The question is then is it possible to configure a sort of hybrid solution, like you can with 6Ghz - WPA2/3 with transition mode? Would a possible solution be Enable FT and check both 802.1X and FT + 802.1X? Or just turn on Adaptive Mode?
Tried to browse the Cisco documentation, but wasn't able to find a section about support/settings to support FT/non-FT devices. Some old discussions and online posts from 2019 or older suggests the Adaptive mode, but I could find any official description of implications, only that this is something that specific clients support like Apple devices.
marce1000
  - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#Enable80211rFastTransition
  M.
8 Replies 8
marce1000
  M.
Thanks! Should have looked at that to begin with, started with the configuration guides.
Follow up question: Would it be possible to run WPA2/3 transition mode to support 6 Ghz and non-6 Ghz devices, and 802.11r mixed mode?
I.E. enable FT and check 802.1X, FT + 802.1X and 802.1X-SHA256
eglinsky2012
When we cut over our first building from 8540s to 9800s two years ago, we had a small percentage of devices that had issues connecting (I forget the exact symptoms/error messages), but the solution was checking of the "802.1x" AKM in addition to "FT + 802.1x" (as noted in the link Marce sent). This seems to cover all devices, since I'm not aware of any that we were unable to get connected after resolving device/account issues, and we are a university/BYOD environment, so that covers many devices of different types, ages, software/driver updates, etc.
I'm very interested in what others say about the question of WPA2/WPA3 transition mode along with 11r mixed mode, since we're still just on WPA2. But there doesn't seem to be an "FT + 802.1x-SHA256" option. @Rich R or @Leo Laohoo, any insight here?
srimal99
@tbnguyen check following https://mac-wifi.com/ciscos-802-11r-ft-settings-adaptive-mode-explained/#:~:text=Summary,SSID%20does%20not%20support%20it
 wpa2/wpa3 can be configure on with transition mode. More details on following
https://mrncciew.com/2020/08/17/wpa3-enterprise/
Scott Fella
There is no one-size-fits all in wireless.  When you are supporting multiple customers, unless they have the same types of wireless devices and do the same sort of function, there is no one-size-fits all.  You will have devices that are old that will not work with WPA2/3, or will break with FT.  It's the same with data rates, you can't have one profile for all your customers. You need to understand each environment and build notes for each so you can figure out what features each client may be able to use and go from there.  Since they are your customers, its what is best for them, not what is simpler to manage.  You will keep them customers if you cater to their needs and environment. Just my opinion.
-Scott
tbnguyen
Completely agree, maybe bad wording on my part. As we also provide the laptops to our customers as well, the goal is to have a baseline config that would be compatible with 90-95% of those clients and do the adjustments thereafter.
@eglinsky2012 Took a pcap and viewed the RSN Information and the AKM list and the FT + 802.1X option on WPA3 is indeed SHA256 encrypted. Came with the number 3 under AKM suite, which matches up with the table here: WPA3-Enterprise | mrn-cciew
This is what is confusing... you provide the laptops, but then you state this: But now I want to include customer environments where you can find all sorts of devices old/new, with/without support for 802.11r.
I'm pretty sure you can eventually get there and figure out what works and doesn't, my concern would be the devices you don't know about and these devices that are old?  You can fix this by having multiple SSID's so you don't have to worry about transition or issue when WPA3/WPA2 is configured.  Again, you are on the right path and testing will allow you to determine what you can and can't do.
-Scott
Rich R
Mixed mode (FT + non-FT) - yes
Transition Mode - I do not recommend.  We tried it and it caused problems - some clients (older drivers and devices) cannot connect at all.  Windows adds a digit onto the SSID name so it looks like a new SSID (network).  If you control your client base then make sure they are all WPA3 compatible.  If not, then better to have separate SSIDs in my opinion.
As for both together - sounds like trouble if even possible/supported.
Also check out https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/wpa3-dg.html
